Headed to the track...got some ?'s
This will be my first time down to Seattle International Raceway and I have no experience in drag racing! All help will be appreciated!
1. How do I remove my rear seats?
2. How do I remove my passenger seat?
3. If you could choose, would you rather drag race on 215/45/R17 Toyo Proxes, 205/50/R16 Falken ZE-502, or 205/45/R16 Pirelli P700-Z's? The 17 inch wheels are Focal and the 16 inch wheels are Fittipaldi. Which setup would yeild me the fastest quarter mile time?
Thanks
Thanks
1. i forget took thm out so long ago
2. ther are 4 12 millimeter bolts under the seat bracket holing it in....just poop off the plastic box coverings on the sides.
3. the pirrellis and lower the air pressure to 20
Just my opinion, but if I were you I wouldnt even worry about the rear seats, I mean since its your first time and all. Just work on your launch and the actual race. Worry about the other **** later maybe next race. But to remove the rear seats if I remeber correctly you take the carpet off the back and then there are bolts that hold in the cushions. Then there are clips on the sides of the backs of the seat that you need to remove.
1. there is a clip between the rear folddown part and wall, pull it out and take out the 2 sides. Then the bottom half is held in by two clips. Just tug on the left side and right side hard seperately.
2. Passanger seat has four bolts. 2 in the front. the rear should have a little plastic cover. remove the cover and remove the bolt.
3. Go on the smaller wheels. u should accelerate a little faster i think. never been to the strip.....
