ITR rear sway on a 97 DX coupe?
Old Apr 22, 2003 | 07:26 PM
Wazup's Avatar
Default ITR rear sway on a 97 DX coupe?
i did a search and most of the topicsw were on what is needed for mounting and what not.
my question is would it be ok to put an ITR rear sway on my coupe as long as i use the beaks kit? right now im using ITR springs and shocks, do i need the front sway bar as well? or can i just put a rear one on?
Old Apr 22, 2003 | 08:37 PM
deviant1's Avatar
Default Re: ITR rear sway on a 97 DX coupe? (Wazup)
no one says you cant put it on. if you put on the rear or front without the other or both for that matter, take it easy until you get used to your cars new handling. accidents are bad! and use the beaks kit.
Old Apr 22, 2003 | 08:57 PM
BagelW's Avatar
Default Re: ITR rear sway on a 97 DX coupe? (deviant1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">no one says you cant put it on. if you put on the rear or front without the other or both for that matter, take it easy until you get used to your cars new handling. accidents are bad! and use the beaks kit.</TD></TR></TABLE>
I second that. Beware of oversteer!
Old Apr 22, 2003 | 09:46 PM
GARBhatch.'s Avatar
Default Re: ITR rear sway on a 97 DX coupe? (BagelW)
ummmm.. yah, there's no punishment for putting only the rear sway bar on. And there is no physical link between the two. Unless you're putting a limited slip along with the front sway, i would just put the rear on for now. But yes it is rather stiff, so beware the back end kicking out.
Old Apr 22, 2003 | 09:58 PM
tonyxcom's Avatar
Default Re: ITR rear sway on a 97 DX coupe? (98Hatch00)
Dont coupes have front sway bars stock?
And yes, dont install the ITR bar without the Beaks.
Old Apr 22, 2003 | 10:25 PM
elwood's Avatar
Default Re: ITR rear sway on a 97 DX coupe? (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom &raquo;</TD></TR><TR><TD CLASS="quote">Don't coupes have front sway bars stock?
And yes, don't install the ITR bar without the Beaks.</TD></TR></TABLE>
Only the ex came with a front. It was like a 19mm.
Sorry to rain on this beaks parade but it looks like 2 bushings and 2 pieces
of metal. Anyone ever try to make it?
Old Apr 22, 2003 | 10:26 PM
tonyxcom's Avatar
Default Re: ITR rear sway on a 97 DX coupe? (d15dude)
Go ahead.
For you to make one QUALITY kit on your own, it will cost a lot more then what the Beaks kit costs.
Bigmojoj27
Nov 26, 2006 08:32 PM
n.e.coupe
May 15, 2006 02:45 PM
milruner
May 2, 2005 05:21 AM
litterbox
May 19, 2004 09:21 AM
deviant1
17
Nov 3, 2002 11:40 PM
