ITR rear sway on a 97 DX coupe?
i did a search and most of the topicsw were on what is needed for mounting and what not.
my question is would it be ok to put an ITR rear sway on my coupe as long as i use the beaks kit? right now im using ITR springs and shocks, do i need the front sway bar as well? or can i just put a rear one on?
Re: ITR rear sway on a 97 DX coupe? (Wazup)
no one says you cant put it on. if you put on the rear or front without the other or both for that matter, take it easy until you get used to your cars new handling. accidents are bad! and use the beaks kit.
Re: ITR rear sway on a 97 DX coupe? (deviant1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 »</TD></TR><TR><TD CLASS="quote">no one says you cant put it on. if you put on the rear or front without the other or both for that matter, take it easy until you get used to your cars new handling. accidents are bad! and use the beaks kit.</TD></TR></TABLE>
I second that. Beware of oversteer!
Re: ITR rear sway on a 97 DX coupe? (BagelW)
ummmm.. yah, there's no punishment for putting only the rear sway bar on. And there is no physical link between the two. Unless you're putting a limited slip along with the front sway, i would just put the rear on for now. But yes it is rather stiff, so beware the back end kicking out.
Re: ITR rear sway on a 97 DX coupe? (98Hatch00)
Dont coupes have front sway bars stock?
And yes, dont install the ITR bar without the Beaks.
Re: ITR rear sway on a 97 DX coupe? (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">Don't coupes have front sway bars stock?
And yes, don't install the ITR bar without the Beaks.</TD></TR></TABLE>
Only the ex came with a front. It was like a 19mm.
Sorry to rain on this beaks parade but it looks like 2 bushings and 2 pieces
of metal. Anyone ever try to make it?
Re: ITR rear sway on a 97 DX coupe? (d15dude)
Go ahead.
For you to make one QUALITY kit on your own, it will cost a lot more then what the Beaks kit costs.
Bigmojoj27
11-26-2006 08:32 PM
