h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd?
Old Apr 22, 2003 | 06:30 PM
SIckH22Atch's Avatar
Default h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd?
bad gauge for power, but 1st gear, I can spin the tires at any RPM, but 2nd, I can not break them lose. I have an lsd, clutch/flywheel, just wondering about you guys. As far as tires... I have crappy snow tires (stock size.)
Old Apr 22, 2003 | 06:52 PM
Newman's Avatar
New User
Default Re: h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd? (SIckH22Atch)
With the Hotshot header on my car, on street tires, I can shift hard into 2nd gear and it would just spin all the way to redline, and spin a little bit in 3rd gear..... I had the stock Honda LSD in my M2F4 tranny.
When I had the 22x7x13 slicks, I did a burn out once from 2nd gear..... didn't sound too good when I dumped the clutch (didn't want the axles to break) so I just did 1st gear burn outs with the slicks, and just feathered it around 6-7000 rpms in the water box.
Old Apr 23, 2003 | 08:19 AM
EK22Tim's Avatar
Default Re: h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd? (Newman)
Wow, that's interesting.. I have GSR rims now with snows on them and I NEVER break loose? Maybe I'm underpowered/doing something wrong? I have the stock H22 LSD and an EK hatch? WEIRD.. it's stock except catback and testpipe, and no airbox, just a cheap filter thing. Just checked my CEL's last night. Nothing but EGR.. running stock P13 too. I'm getting that chipped ASAP from Kenji.
Old Apr 23, 2003 | 08:31 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">When I had the 22x7x13 slicks, I did a burn out once from 2nd gear..... didn't sound too good when I dumped the clutch (didn't want the axles to break) so I just did 1st gear burn outs with the slicks, and just feathered it around 6-7000 rpms in the water box.
Dude! You started your burnout in 2nd?! I start in 1st til rev limiter, then shift to 2nd really quick...you'll still be spinning, so you won't be going anywhere anyways.
BTW EK22Tim, if you're not spinning, you're accelerating. Don't worry about breaking the tires loose...put it down to the pavement!
Old Apr 23, 2003 | 09:20 AM
Jonathan_ED3's Avatar
Default Re: h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd? (98CTRCoupe)
exactly. Spinning your tires doesn't help anything
Old Apr 23, 2003 | 09:38 AM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe &raquo;</TD></TR><TR><TD CLASS="quote">
Dude! You started your burnout in 2nd?! I start in 1st til rev limiter, then shift to 2nd really quick...you'll still be spinning, so you won't be going anywhere anyways. </TD></TR></TABLE>
With my old turbo B20 setup (same 22x7x13 slicks) at 12 lbs of boost, I'd drop it in 2nd gear all the time in the water box at 6000 rpms and they'd warm up pretty good. Otherwise, if I started in first, I'd be bouncing off of the 8500 rev-limiter right away (with a chipped LS ECU). That's why I tried it with the H22 but like most all-motor setups, it doesn't like to be dropped in 2nd gear. Hey, I had to try so all of you guys who drag your H22 Civics would know
Old Apr 23, 2003 | 11:50 AM
Finest's Avatar
thanx for looking out for us! LOL!
Old Apr 23, 2003 | 12:39 PM
EK22Tim's Avatar
LOL true, true, if you're not spinnign you're accelerating, but it makes me worry that mine's underpowered. That's all. Comp looks great on the motor, and no engine codes. I guess I just have a freak! It pulls nicely though.
Old Apr 23, 2003 | 09:11 PM
JDMH22HATCH's Avatar
Default Re: h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd? (EK22Tim)
Man, I wish my **** would hook up as good as you. If I punch it in first it spins, and like Newman, if I launch it, it spins through first, second, and tad in third. Traction has been my biggest problem so far. Did that traction bar issue ever get resolved?
Old Apr 23, 2003 | 09:20 PM
fastwanabe's Avatar
Default Re: h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd? (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Man, I wish my **** would hook up as good as you. If I punch it in first it spins, and like Newman, if I launch it, it spins through first, second, and tad in third. Traction has been my biggest problem so far. Did that traction bar issue ever get resolved?</TD></TR></TABLE>
when I had my 195/50/15 I could roast them through 3rd, but since I've got my 205's I can only chirp them into 3rd. My H22 does not like to start in 2nd for burnouts it smoke the clutch more than the tires
Old Apr 24, 2003 | 04:08 AM
EK22Tim's Avatar
Default Re: h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd? (fastwanabe)
Well, I DO have 205 series snows, and I got the race kit from Newman, which includes the front cross mount for H22's ( by the way)
I wonder if that would have something to do with it? Other than that, I'm running Skunk2 coils and stock shocks for now, but my AGX's are on order. I donno why guys. It's weird. maybe cux my EK's heavier than the EG's? Kenlude97 drove my car and said it's got less spin than his H22 prelude, so I must be doing something right?? Oh well, she hooks up every time!
Old Apr 24, 2003 | 10:51 AM
H22ek4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK22Tim &raquo;</TD></TR><TR><TD CLASS="quote">Well, I DO have 205 series snows, and I got the race kit from Newman, which includes the front cross mount for H22's ( by the way)
I wonder if that would have something to do with it? Other than that, I'm running Skunk2 coils and stock shocks for now, but my AGX's are on order. I donno why guys. It's weird. maybe cux my EK's heavier than the EG's? Kenlude97 drove my car and said it's got less spin than his H22 prelude, so I must be doing something right?? Oh well, she hooks up every time!</TD></TR></TABLE>
I have an ek using the hcp race mounts and when using 13inch steelies I would spin all of 2nd and a little on 3rd, but right now I'm using 205 yok paradas and in first gear it would break lose if I punch it hard and it would start sliding in 2nd and would chirp in 3rd.
Old Apr 24, 2003 | 10:54 AM
EK22Tim's Avatar
aww, man you guys are makin me think there's something wrong with my motor?
Old Apr 24, 2003 | 01:48 PM
google's Avatar
Default Re: (EK22Tim)
i have 215 yok paradas and it all depends if ur launching or not. if i just go slow in first and mash second itll burn for a little with the quiafe and then third there is a notciable loss of traction. but it depends what clutch ur using too.
Old Apr 24, 2003 | 02:22 PM
cccya's Avatar
Default Re: (1320in11)
on the factory, wheels with snows on i can spin 2nd hard. with my 16" 205 yoks, i can get chirps out of third all day (no LSD )
I wish i had a LSD
Old Apr 24, 2003 | 05:45 PM
hondaeg5's Avatar
Default Re: (cccya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cccya &raquo;</TD></TR><TR><TD CLASS="quote"> (no LSD )
I wish i had a LSD</TD></TR></TABLE>
me too! . **** i wish i had my car running! hopefully soon as i get my damn fan! they are taking forever.
Old Apr 24, 2003 | 05:50 PM
fastwanabe's Avatar
Default Re: (cccya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cccya &raquo;</TD></TR><TR><TD CLASS="quote">on the factory, wheels with snows on i can spin 2nd hard. with my 16" 205 yoks, i can get chirps out of third all day (no LSD )
yeah, i wish i had lsd too.
BTW.... how does someone go about doing 2 tire burnout with a non.LSD trans? I've been able to do this at the track but I've never been able to figure out how or why.
Old Apr 24, 2003 | 06:15 PM
poison's Avatar
Default Re: (fastwanabe)
damnit, I want lsd too.
i wanna track me down a Euro R tranny. argh. those are rare as hell.
I would turn your wheels. fastwanabe, you should be able to burn both of them w/ the torque you have.
you only spinnin one tire?
Old Apr 24, 2003 | 06:20 PM
fastwanabe's Avatar
Default Re: (poison)
60% of the time its one tire. When they both grab I leave 2 even strips but like I said I dont know how I do it. I know for sure my tranny is NON LSD.
Old Apr 24, 2003 | 06:21 PM
hondaeg5's Avatar
what do you think would be better brandon? buy a quaife or look for a trans with a stock lsd?
Old Apr 24, 2003 | 06:22 PM
poison's Avatar
hmm, both of mine spin and I have the non-LSD as well. (M2A4)
What size tires do you have man?
Old Apr 24, 2003 | 06:23 PM
poison's Avatar
Default Re: (hondaeg5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg5 &raquo;</TD></TR><TR><TD CLASS="quote">what do you think would be better brandon? buy a quaife or look for a trans with a stock lsd?</TD></TR></TABLE>
stock lsd! quaife owns, but that is like $700-800. The M2B4 or even if you can find the Euro R tranny would be around that exact price.
Old Apr 24, 2003 | 06:27 PM
hondaeg5's Avatar
the m2b4 is pretty hard to find-isnt it?
Old Apr 24, 2003 | 06:33 PM
poison's Avatar
nah, not entirely difficult. a lot of importers don't have too difficult of a time gettin 'em.
Old Apr 24, 2003 | 06:41 PM
hondaeg5's Avatar
do you think steve from hmotorsonline can get one?
