CEL CODE 43!!! HELP....
Old Apr 22, 2003 | 05:53 PM
degooser's Avatar
Default CEL CODE 43!!! HELP....
ok i have change the o2 sensor and i still get the cel...
fuel filter 8 months ago...
93 civic coupe 94 b18c
car runs fine with the cel on, but it still burns..
but it only comes on when the car has been sitting for a while...
if i drive it...cel comes on...i turn off the car...reset the ecu...car runs fine..cel no come on..
but if i let it sit for a few hours...it will come on???
anybody please help...
Old Apr 22, 2003 | 05:56 PM
fOmaNPu's Avatar
Fuel Supply System
defective or malfunctioning fuel supply system
Something is wrong with your fuel supply system. Have a knowledgable friend look at it, or take it to the shop.
Old Apr 22, 2003 | 05:57 PM
degooser's Avatar
Default Re: (fOmaNPu)
could it be the fuel pump...the stocker is still in there after 190,000 miles...
but it runs fine....
Old Apr 22, 2003 | 05:58 PM
boostedcivicsir's Avatar
Mr. Badwrench
check that your idle fuel pressure is within spec. i have had that problem before.
Old Apr 22, 2003 | 05:59 PM
degooser's Avatar
Default Re: (boostedcivicsir)
its the stock fuel press reg...how would i change pressure on a stock regulator?
Old Apr 22, 2003 | 06:04 PM
Mr. Badwrench
Default Re: (degooser)
usually pertains to one that has a riser. sorry.....but make sure the fuel pressure is within spec.
Old Apr 22, 2003 | 06:09 PM
degooser's Avatar
anyone have any first hand experience with this or had the same problem???
I am starting to pull my hair out....
Old Apr 22, 2003 | 06:41 PM
whatVTEC's Avatar
I have the same damn problem. I don't know what it is either. Whenever I reset it, it stays off for a few days and comes back?
Old Apr 22, 2003 | 06:42 PM
degooser's Avatar
HELP!!!
so its just when my car is totally cold and it is starting to warm up is when the code comes on...
Old Apr 22, 2003 | 08:48 PM
Sivicfied's Avatar
I get that plus #7 and another one for the o2 sensor. But no fix yet.
Old Apr 22, 2003 | 09:10 PM
hndarcrb18c1's Avatar
Default Re: (Sivicfied)
What Ecu are you running???
Old Apr 22, 2003 | 09:36 PM
DarkCyde SI's Avatar
Default Re: (hndarcrb18c1)
i had that exact same code but i changed my o2 and it stopped. my gas mileage got a lot better too since it was running rich while the light would go on.
Old Apr 23, 2003 | 05:16 AM
degooser's Avatar
usdm p72
Jahmani
Nov 9, 2018 03:53 PM
ahtublao
29
Feb 23, 2010 08:21 PM
Dubs13
Aug 27, 2009 07:22 PM
IwanAturBo
Mar 16, 2003 06:53 PM
blackcracker
Oct 25, 2002 06:13 PM
