** Passenger side Floor is ALWAYS WET after rain **
I have this major problem, there is not rust no where on the car and the car had never been into an accident or somewhat... But, after it rained a lot, the passenger side floor is always soaked with water... I can't see from where it is coming from, anyone here ever experimented such situation ?
Thanks
Thanks
have you recently had your windshield replaced? Or do you know if it has ever been replaced?
yaeh...have all ur seals checked...window seals, door seals, hood seals, and trunk seals...my friends coupe is leaking...we believe its a leaky trunk seal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 »</TD></TR><TR><TD CLASS="quote">does it only happen when you drive in the rain, i used to have that problem, ended up being a leak from the wheel well.</TD></TR></TABLE>
yeah and check that seal too
It only happens when the car is parked... especially if the right side of the car (passenger) is tilting lower than the driver side...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 »</TD></TR><TR><TD CLASS="quote">leaky door seal...</TD></TR></TABLE>
I will go with that to. Mine does the same thing. It leaks like above the handle for the window where the door closes.
92EGMINIME
Apr 8, 2009 12:34 AM
eddiecut
Jan 2, 2007 08:06 AM
N1ghtM0nkey
16
Jul 13, 2006 11:55 PM
