Fuel questions
Old Apr 22, 2003 | 02:43 PM
itr501's Avatar
Default Fuel questions
When I start my bike, it comes alive but the revs slowly drop and eventually it dies out. I'm thinking maybe i should leave the choke on longer, but I did leave it on for a reasonable amount of time.
Today, I got impatient and drove away with partial choke. Soon after the engine died out when I pulled in the clutch to downshift. Did this happen because I was driving with the choke on? It refused to start after that, but i waited awhile and played around with the petcock settings, put it in all the modes, and finally it came alive after a few minutes.
Old Apr 22, 2003 | 02:58 PM
Turbogixxer's Avatar
Default Re: Fuel questions (itr501)
how old is the bike?
Old Apr 22, 2003 | 03:05 PM
itr501's Avatar
Default Re: Fuel questions (turbogixxer)
about 20 years.. it usually runs fine, this is the first time its ever done this.
Old Apr 22, 2003 | 03:09 PM
when is the last time that you did maintenance on the bike? like cleaning the carbs and fuel filter and whatnot?
Old Apr 22, 2003 | 03:43 PM
itr501's Avatar
hmmm i did all that about 1k miles ago. but that was a few years ago. I put it into storage soon after and only recently have I brought it out again.
Old Apr 22, 2003 | 04:30 PM
What kind of prep did you do for the bike before you put it into storage?
Old Apr 22, 2003 | 04:37 PM
itr501's Avatar
well unfortunately i didn't put fuel stabilizers. I just parked it and that was that. I was expecting the worse when i took it out of storage but it started right up and I've been riding it for about a year now. Do you think I should clean the carbs again? or at flush it with carb cleaner?
Old Apr 22, 2003 | 04:45 PM
I would take it a shop and have them take the carbs off and clean them, or just do it yourself if you can.
Old Apr 25, 2003 | 02:49 PM
fiRemaP's Avatar
yes you probably want to get the carbs cleaned out thoroughly if it hasn't been done in a while.. can't hurt
just a side note: twisting the throttle with the choke on will make the bike run super rich and will foul the plugs given enough time
check your spark plugs
Juswanaride
Honda Motorcycles
Feb 1, 2011 12:58 PM
Xentropa
Honda Motorcycles
Jan 2, 2009 04:28 AM
TurboEM1
Honda Motorcycles
20
Jun 26, 2007 11:21 AM
GeorgeY
Honda Motorcycles
May 29, 2004 02:13 PM
wyv
Honda Motorcycles
12
Apr 24, 2001 06:33 AM
