13" hx wheels
Old Apr 22, 2003 | 02:17 PM
euclid's Avatar
Default 13" hx wheels
does anyone run the 13" civic hx rims on the 4 wheel disk integras? there is a bit of a debate going on in the civic forum about whether or not they fit over the 10.3" front brakes.... thanks
Old Apr 22, 2003 | 02:25 PM
Passaudi1.8t's Avatar
New User
Default Re: 13" hx wheels (euclid)
You will either need spacers, or you'll have to shave a little bit off the brake calipers. It can be done, just takes a little effort to make it work.
Old Apr 22, 2003 | 02:45 PM
euclid's Avatar
Default Re: 13" hx wheels (vtecivicex)
so the problem isnt the diameter being too small, its the caliper rubbing the front of the wheel?
Old Apr 22, 2003 | 02:50 PM
Outsider GSR's Avatar
they are 14" wheels, shaving of the caliper wrong will mess up your brakes real good.
Old Apr 22, 2003 | 03:10 PM
euclid's Avatar
Default Re: 13" hx wheels (Outsider GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsider GSR &raquo;</TD></TR><TR><TD CLASS="quote">they are 14" wheels, shaving of the caliper wrong will mess up your brakes real good. </TD></TR></TABLE>
my bad...
well then i just need to know if anyone has been able to fit 13" wheels on an integra, front or rear?
Old Apr 22, 2003 | 05:03 PM
zigs's Avatar
HX wheels are 14in but they also made basically the same wheel in a 13in found on 92-95 VX hatches.
Old Apr 22, 2003 | 05:07 PM
CoryTurner's Avatar
hx=14"
vx=13" i had the hx wheels on my teg for a few weeks. needed to cut one mm off of part of my caliper. didn't make a differance. just cut where it rubbed.
Old Apr 22, 2003 | 05:27 PM
BlueTeg's Avatar
Default Re: (CoryTurner)
If you're having second thoughts on shaving the brakes, you can get spacers that will allow the rim to clear the brakes.
Old Apr 22, 2003 | 05:46 PM
96dc2's Avatar
Default Re: (BlueTeg)
13's will not clear the fronts, but will clear the rears.
cherroneballs
10
May 1, 2008 04:15 PM
Dc2 Joe
Jan 13, 2006 12:38 PM
Yak BallZ
Feb 9, 2005 03:40 PM
12 oz.
May 9, 2003 11:29 PM
Chip398193
Jul 25, 2001 11:35 AM
