Anybody in NOVA have access to a bushing press??
Old Apr 22, 2003 | 11:36 AM
Kalokohan's Avatar
New User
Default Anybody in NOVA have access to a bushing press??
I have a set of rear trailing arms off a 94 si hatch that I am about to install on my 93 cx but I would like to replace the bushings before hand. Can anyone help me? I know you can torch the existing bushings out but you need a press to put the new ones in correct? CDE just quoted me $70-$90 to put 2 bushings in.
Old Apr 22, 2003 | 11:48 AM
White Lightnin's Avatar
Default Re: Anybody in NOVA have access to a bushing press?? (Kalokohan)
Here is the method that only the true masters know:
Take the new LCA's and torch the old bushings till all the rubber is gone.
Then get out a hacksaw and remove its blade
Place the blade through the now vacant hole in the LCA and saw out the metal sleeves.
Hammer them out with a drift once they are loose.
Then insert the new bushings. You can almost do it by hand. Use a vice or somethign similar.
That is for Poly bushings. Im not sure on how to reinstall stock ones.
Old Apr 22, 2003 | 12:16 PM
Kalokohan's Avatar
New User
Default Re: Anybody in NOVA have access to a bushing press?? (White Lightnin)
I was told about this method by a friend already and you are right on the money.......but for the price of a torch, hachsaw, vice grip, etc... I could just get the shop to do it for half the time. I'm just trying to get the hook up for a 20 min. job with a press. Paying the charge is not a problem, I would rather pay a friend or H-T member.
Old Apr 22, 2003 | 12:44 PM
hybridreams's Avatar
Bushings are a bitch from what I hear.
Good luck
Old Apr 22, 2003 | 01:00 PM
Kalokohan's Avatar
New User
Default Re: Anybody in NOVA have access to a bushing press?? (mr. hybridreams)
Like White lightning said you can torch those out but pressing the new ones in will be the challenge.
Anybody else?
Old Apr 22, 2003 | 01:14 PM
Mike P.'s Avatar
25 Year Member
I did mine a couple weekends ago and it took about 5 minutes each to press the old one out and the new one in. Too bad I'm in MD.
Old Apr 22, 2003 | 01:38 PM
Default Re: Anybody in NOVA have access to a bushing press?? (Mike P.)
Are you doing stock or poly bushings?
Im thinking you'd need a press for stock ones b/c of the metal sleeves. Poly ones go in with little trouble.
All the tools are cheap too.
Old Apr 23, 2003 | 05:17 AM
Kalokohan's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike P. &raquo;</TD></TR><TR><TD CLASS="quote">I did mine a couple weekends ago and it took about 5 minutes each to press the old one out and the new one in. Too bad I'm in MD.</TD></TR></TABLE>
Where in MD are you? I'd be willing to meet you. The trailing arms are OFF the car.
Old Apr 23, 2003 | 11:38 AM
confidence's Avatar
if they are ES bushing you dont take out the shell. just remove the rubber and install. you can use large washers and a bolt and nut to press them in. (the install pics that come with the bushings show this method) a lil tip to help you out is to put the bushing in the freezer overnight before you install them. they'll shrink a tad and it becomes a lil easier to install. still a pain in the *** tho
in1accord
Aug 31, 2007 04:32 AM
sicegcivic
Mar 2, 2006 07:22 AM
tthomass
Suspension & Brakes
Jan 17, 2005 05:32 AM
johnzm
Nov 16, 2002 04:11 PM
Jaminak
23
Jun 6, 2002 12:57 PM
