Timing is wayyyy offfffff.....HELP!!!!
Old Apr 22, 2003 | 10:38 AM
incognitoracerr's Avatar
Default Timing is wayyyy offfffff.....HELP!!!!
Guys, A friend of mine just got his head ported and polish (stage 4)...the shop did all the porting and polishing...we installed the head ourselves...we put everyting top dead center and both cams are in the up position...everything is correct but when we check the timing its off by like 7 degress. The car is an acura b18a1 with crower cams with a lift of about 430. We can't get the timing right therefore the car stalls...what do we need to do?
Old Apr 22, 2003 | 10:54 AM
IN VTEC's Avatar
Default Re: Timing is wayyyy offfffff.....HELP!!!! (incognitoracerr)
Are you using adjustable cam gears?
Did you degree the cams in?
The shop who worked the head might have milled the deck on the head.
Old Apr 22, 2003 | 10:56 AM
psi420's Avatar
Head is milled for sure, timing of course is off.
Old Apr 22, 2003 | 11:02 AM
Default Re: Timing is wayyyy offfffff.....HELP!!!! (IN VTEC)
They definately milled the head...sorry forgot to mention that...so what does he need? Adjustale cam gears?...he has the stock cam gears and they are in correct timing...
Old Apr 22, 2003 | 12:43 PM
dfoxengr's Avatar
yeah you need adj ones..
Old Apr 22, 2003 | 12:47 PM
psi420's Avatar
Default Re: Timing is wayyyy offfffff.....HELP!!!! (hybridvteceg)
Yeah get adj gears, make up timing difference on the dist side.
gATOr65
Dec 27, 2005 02:03 PM
DcWest
Sep 27, 2005 12:49 PM
scUba-stEve
13
May 15, 2005 08:47 PM
JDMs1eeper
18
Aug 24, 2003 12:01 AM
Edwin
Jul 17, 2002 05:58 AM
