Reoccuring idle problem HELP!!!
Old Apr 22, 2003 | 08:45 AM
yellaboi's Avatar
Default Reoccuring idle problem HELP!!!
I have had this problem with surging idle for some time.
Have searched and tried every little fix.
I read through the helms troubleshooting and replaced everything including ecu.
Finally ended up swapping intake manifold(complete) with another that I had and the problem stopped.
Now all of a sudden its doing it again.
Car is 91 integra
When I replaced the IM I also replaced the fuel filter.
Coolant is full and bled of air.
What could be the problem?????
Old Apr 22, 2003 | 09:26 AM
kyle h.'s Avatar
Default Re: Reoccuring idle problem HELP!!! (yellaboi)
intake manifold gasket sealing up right? positive the coolant is full? could be leaking out somewhere?
Old Apr 22, 2003 | 09:30 AM
yellaboi's Avatar
Default Re: Reoccuring idle problem HELP!!! (kyle h.)
coolant is full, IM gasket is new and has been fine for the last 2 weeks since I changed it
Old Apr 22, 2003 | 09:40 AM
NiiS's Avatar
IACV or FICV, the latter was my problem...What pain to diagnose, but cake to fix.
Old Apr 22, 2003 | 09:51 AM
yellaboi's Avatar
Default Re: Reoccuring idle problem HELP!!! (sinister)
is IACV and FICV the same or different part. I swapped the IACV and didn't help but of course afterward I swapped the whole IM (including IAC) and that fixed it temporarily
Old Apr 22, 2003 | 09:53 AM
NiiS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellaboi &raquo;</TD></TR><TR><TD CLASS="quote">is IACV and FICV the same or different part. I swapped the IACV and didn't help but of course afterward I swapped the whole IM (including IAC) and that fixed it temporarily</TD></TR></TABLE>
They are seperate parts, the fast idle valve(FICV) is a wierd thermostat kind of thing, usually behind the IM, you`ll find it in Helms..
Old Apr 22, 2003 | 09:57 AM
yellaboi's Avatar
OK I didn't understand the abbreviation, haven't had much time to check everything again since it started again but that's usually my second or third step. I hope it doesn't need replaced
pacificrim
Feb 15, 2009 08:56 AM
bluelsvtecda9
Jan 21, 2007 11:27 PM
swads21
Jul 3, 2006 06:38 AM
