Leaking Clutch Slave Cylinder Replace or Repair?
My Clutch slave cylinder has recently sprung a leak, should I replace the seals with new items from Acura, or scrap it all together and fit a new or used unit?
Anyone fixed one in the past?
Here are some pics. It is leaking where the piston comes from the cylinder.
The car is a JDM Integra ZX (ZC engine with twin carbs)
http://www.clubi.ie/bpl/integra/Clutchslave/
You aren't gonna know for sure till you take it apart. If the rubber parts are shot, then you're OK. If the cylinder walls are scored or corroded, then the new rubber parts aren't going to help.
Turbo D17
Dec 9, 2004 02:31 PM
