Clutch master cylinder
Hi. I have a 99 Honda civic LX and the master clutch cylinder is leaking fluid (pic attached). How do I fix the leak on the clutch master cylinder? What parts do I need to replace?
Re: Clutch master cylinder
i would just replace it its not too hard, 3 12mm bolts to remove it off the clutch petal itself, then a 10mm i believe for the line at the top of the master in the engine bay and then the hose and it should just pull out, i saw one at my local auto parts store for like 30$ then you just gotta re bleed the system
Should I replace the slave clutch cylinder at the same time I replace the master clutch cylinder?
gooblinn258
01-18-2014 05:02 PM
