JDM CTR/ITR steering wheel.....?
Old Jun 29, 2001 | 04:39 AM
Type R106's Avatar
New User
Default JDM CTR/ITR steering wheel.....?
What is the difference between the CTR Momo steering wheel and the ITR Momo steering wheel?
Old Jun 29, 2001 | 05:27 AM
Trey's Avatar
25 Year Member
Default Re: JDM CTR/ITR steering wheel.....? (Type R106)
The inner splines are the only difference. If you have a teg, get the ITR one and it will bolt up fo so.....
Old Jun 29, 2001 | 06:46 AM
Mike M's Avatar
Founding Member
Default Re: JDM CTR/ITR steering wheel.....? (Trey)
Exactly the Splines are different between the EK (CTR) Civics and the DC2 Integras
BTW I have 2 used units coming in in about 2 weeks ones sold so let me know if your interested
Old Jun 29, 2001 | 06:48 AM
Type R106's Avatar
New User
Default Re: JDM CTR/ITR steering wheel.....? (TypeRmsm)
Does the CTR steering wheel work on the USDM ITR without mod?
Old Jun 29, 2001 | 07:11 AM
Mike M's Avatar
Founding Member
NO CTR steering wheel has a Different Spline and will Not fit
The CTR which is an EK Civic and the S2000 have the same spline
The ITR which is a DC2 and the EG model Civics have the same spline
So no a wheel from a CTR wont fit in an ITR and Vice versa
Old Jun 29, 2001 | 07:55 AM
Type R106's Avatar
New User
Thanks for clearing that up Mike.
Old Jun 29, 2001 | 08:45 AM
97 TYPE-R 312's Avatar
Tuan, I have a JDM CTR SRS MOMO S/W here if you want to get an idea. I'll show the the difference between the hubs on both wheels as well if you want. Email me.
Thanks,
Victor Perri II
Old Jun 29, 2001 | 08:57 AM
Type R106's Avatar
New User
Default Re: JDM CTR/ITR steering wheel.....? (97 TYPE-R 312)
You got mail Victor.
Thanks
Old Jun 29, 2001 | 09:57 AM
Chui's Avatar
From: Somewhere in the MidWest..., The MidWest..., USA
Would it be possible to post those pics here? Thanks in advance.
Old Jun 30, 2001 | 07:34 AM
Chui's Avatar
Default Re: JDM CTR/ITR steering wheel.....? (George Knighton)
Victor, would it be possible to re-slot the steering wheel hub to fit? In the ITR the slots are horizontal when the steering wheel is straight and in the S2K they are vertical. Or could the canceling sleeve be interchangeable on the cars?
Old Jun 30, 2001 | 07:39 AM
tracktime's Avatar
Default Re: JDM CTR/ITR steering wheel.....? (KJR)
The diameter of the "hole" in the CTR hub adapter is too large for the steering shaft on your ITR, so machining a CTR hub to fit an ITR will NOT work..
What I did was that I had a friend of mine get someone to machine me a new hub to fit the DC2.. worked for me..
-Harry
neo_
Feb 26, 2009 05:50 PM
machgo5go
Dec 9, 2007 04:56 PM
VR4ownzU
Apr 9, 2007 06:07 PM
speedymon
Jun 14, 2003 06:29 PM
EkREV
Sep 15, 2001 06:28 AM
