sohc turbo questions...
im about to install my kit
anyhow..fuel questions...
will the fmu supply enough fuel or will i need an inline pump?
this is on 5.5lbs of boost...
what will i need later on to boost more safely?
FMU + stock fuel pump = new motor.
You might get away with it for a little while, but it'll catch up to you sooner or later when your pump quits while trying to flow fuel at 100psi of rail pressure.
So should you put an inline pump in or should you put a bigger pump in your tank. I heard that at low PSI (like 6) you need an FMU, but the stock internals and fuel would handel the load.
red civic standard
Oct 10, 2002 07:47 AM
