Running RA1s backwards
Old Apr 22, 2003 | 05:31 AM
BABY NSX's Avatar
Default Running RA1s backwards
After the expo I found that my left side RA1s fairly worn while the ride side tires were almost new. I'd like to know what your thoughts are on running the right side tires on the left side of the car so that I can even out the tire wear. The tread pattern is directional but that soon disappears anyway. I guess the important question is whether the construction might be different. I know the Khumos I was running last year could be run in either direction (they only manufactured left side tires)
Any thoughts?
Old Apr 22, 2003 | 05:45 AM
rainman's Avatar
Default Re: Running RA1s backwards (BABY NSX)
It doesn't matter - you can flip them from one side of the car to the other, flip them on the wheels, whatever your pleasure. The direction is only a concern if you actually have enough tread left to push water out from underneath the car as that is what the unidirectional tread is designed for.
Old Apr 22, 2003 | 05:47 AM
BABY NSX's Avatar
Default Re: Running RA1s backwards (rainman)
I was thinking the same thing, but wanted some feedback before I actually swapped them over. I don't want to be bothered re-mounting them.
Old Apr 22, 2003 | 06:30 AM
AW's Avatar
AW
Yep, you can run them backwards if needed as long as you do not need them for wet weather. Done it before and it works fine.
AW
canuck-mx6's Avatar
Hey Doug, nice job on the track, you could have pushed a little harder considering that you were running R compounds
Old Apr 22, 2003 | 06:46 AM
BABY NSX's Avatar
Default Re: Running RA1s backwards (canuck-mx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 &raquo;</TD></TR><TR><TD CLASS="quote">Hey Doug, nice job on the track, you could have pushed a little harder considering that you were running R compounds </TD></TR></TABLE>
Thanks, but I could have pushed ALOT harder... I think I was pretty quick through the front half of the track but never took the back half close to the cars ultimate limits. If you watch my video you can see me exiting the blind right in the middle of the track suggesting allot more speed was possible (especially considering my lift at its entry). Second, I was coasting through the right hand kink at about 200km/h at the top of fourth. The car could have taken another 20 or so km/h through there but that made for a very hairy braking zone from 5th down to 2nd.
Watching my own track footage has taught me allot about where I could have picked up allot more time
Old Apr 22, 2003 | 09:20 AM
Big Phat R's Avatar
go ahead and swap em'
Old Apr 22, 2003 | 11:54 AM
sa04's Avatar
Go ahead, RA-1s shouldn't have a problem. Same with Hoosier R3S03's
Were youre Kumho's the Victoracers or the new ECSTA V700s? I had a pair of shaved ECSTAs that I tried to swap left to right after a 90 minutes race, and they chunked up horribly. Just for the record I can't recommend swapping these tires at all (or even purchasing them for that matter).
Just my $.02
Old Apr 22, 2003 | 12:13 PM
rainman's Avatar
Default Re: Running RA1s backwards (sa04)
I know that the chunking you encountered on your Ecsta V700's was not because you swapped from side to side. I experienced the exact same results without swapping. Many others have had the same thing happen - they just seem to be far inferior to the Victoracers and I'll never buy them again.
94accordsedan
Aug 16, 2005 10:36 AM
JAI-DM
Oct 15, 2004 05:13 PM
nEoMuGen
Sep 7, 2002 04:17 AM
4drRacer
Apr 14, 2002 05:57 PM
