wireing up an OBD2 Distributor in an OBD0 crx
Old Apr 21, 2003 | 09:00 PM
DOHCarp's Avatar
Default wireing up an OBD2 Distributor in an OBD0 crx
I am running a B18c1 In 1988 crx si
OBD0 TO OBD1 ECU conv harness
P28 ECU
obd0 injectors with the resistor box
So I am trying run the engine and electronics as OBD1
I rewired my engine harnes as follow to accomidate the OBD2 distributor
Non-OBD Wire color -OBDII Wire color
blue/yel to white
blue/grn to orn
white(small) to blue/yel
orn to blue/grn
wh/blue to wh/blue
orn/blue to orn/blue
Blue goes to OBDIIblue (tach)
non-OBD Black/yellow goes to OBDII black/yellow
non-OBD (large) white goes to OBDII yellow/grn
is this the right way to wire up the distributor?
thanks
Old Apr 22, 2003 | 07:03 AM
DOHCarp's Avatar
Default Re: wireing up an OBD2 Distributor in an OBD0 crx (DOHCarp)
i know someone has done this swap before can anyone help me?
thanks
Old Apr 22, 2003 | 05:45 PM
DOHCarp's Avatar
ttt
come on Im in some serious trouble I need a car.
Old Apr 23, 2003 | 09:50 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp &raquo;</TD></TR><TR><TD CLASS="quote">I am running a B18c1 In 1988 crx si
P28 ECU
blue/yel to white
blue/grn to orn
orn to blue/grn
wh/blue to wh/blue
thanks</TD></TR></TABLE>
unless you have schematics on both a obd0 and obdII distributor, it's a trial and error thing. just use your common sense when it comes to the colors, and before you get any farther, check to see if the coil and igniter in that distributor are in good working order! good luck!
Old Sep 19, 2006 | 05:24 PM
6doorsentra's Avatar
im with you-help
reek
46
Sep 12, 2010 05:01 PM
AllMotorB16RoadRacer
11
Mar 22, 2008 12:48 PM
tvstealer
Mar 14, 2006 07:07 PM
DOHCarp
11
Apr 18, 2003 07:36 PM
