please help with rear disc??????????
ok ive done the rear disc conversion on 2 91 civics (my little bros and mine) and neither have worked right. The first, my little bros had alot of toe in on the passenger side. We put in new trailing arm bushings then had it aligned and it was still way off then we tried the integra dog bones and they seemed to short.(gave up went back to drum) Now mine has alot of positive camber on passenger side do i need the integra UCAs or what i thought this was an easy upgrade oh yeah and this is 2 different sets of rear brakes what am i doing wrong ????? please help
You didn't use any Integra parts other than the trailing arms did you? Because your supposed to use your Civic/CRX UCAs, LCAs, and all that crap.
You shouldn't have to touch the compensator arms or anything else. It should be an out and in ordeal, that's kind of weird. Not to rub it your face or anything but mine was a snap. You might to check for staightness like you said. Did the car you pulled the trailing arms off of have rearend damage?
nighttrain33
Jul 29, 2004 02:23 PM
dng
May 25, 2004 07:29 AM
