Too much oil bad for the R?
I don't know, but it's probably better to just FILL it up and check it every once in a while. Whey would you want to overfill? You'll probably end up not checking it as often because you'll tell yourself that you have more than enough - then one day VTEC will cut out!
When I go to Acura to get my oil changed I give them 5 quarts of Mobil 1. They always give me 1/2 a quart back. The manual says 4.25 quarts right? Thats only a 5% difference, I would think it would be that bad....
Too much is just as bad as not enough sometimes.
Photo?
Yes,
What I've heard is that too much oil can cause the crank to "froth" the oil, so that it doesn't flow. When it doesn't flow, your motor gets starved for oil and bad things happen, very quickly.
As stated, I don't think that .25 or .5 a quart are critical amounts. Maybe 1 or more quarts too much?
Thoughts on how much is enough to cause a problem?
Photo?
FB
Photo?
FB
Your not supposed to fill it till it dribbles out the fill hole??? OH wait was that for the Tranny?? hehe
Supposedly too much is as bad as too little. Or so I've heard... I've heard the churning theory as well... sounds like it would make sense.
Mobil 1 (and basically all synthetics) resist foaming... One of the primary advantages to synth. Others are more stability at temp, and better shear resistance (in particular, on the cylinder walls).
[Modified by FBP_1171, 12:38 PM 6/29/2001]
No more to add, but..
she is an import model or somethin.
http://members4.clubphoto.com/witar3...m/photo21.jpg?
isn't that the cross-eyed kaila Yu, a chinese chica?
yoshi - who dun care if she's cross-eyed
also, I"ll leave this pic up for another 15min, at which time it will be removed
<~~~aiko tanaka for those that care..
not as good as the dude with **** chicks..but hey i just turned 18 a couple months ago...
[Modified by da_rockwilda, 2:03 AM 6/30/2001]
