DVC questions...
i have an mtx 8302 amp..it runs around 400-425x1...and i want to hook up my 12' subs to it..right now they're wired series w/ a 4ohm load...will my amp hurt my subs..my subs are 300RMS and 1200 PEAK....my amp is also 4ohm stable...just wondering about the amps wattage vs the subs wattage...is it safe to push it with this amp..???
yeah my amp runs stable at 4...would i get more out of them if i wired them down to 1ohm...oh btw, i tried them at 4...they hit hard as hell..
If your subs hit hard as hell at 4ohms, don't bother messing with it. Your amp runs cooler at 4 ohms. Also, I am not sure if your MTX is capable of handling a 1 ohm load, you might want to check up on that before wiring the subs differently. Also, I am pretty sure that if you wire them parallel instead of a series it will be a 2ohm load instead of 1, which I think your amp is stable at.
bradykiller
Audio / Security / Video
Mar 31, 2004 06:48 PM
