NSX caliper review (3 track days)
Old Apr 21, 2003 | 03:32 PM
Dropspeed's Avatar
Default NSX caliper review (3 track days)
I finally got to put my NSX calipers and legend rotors to the test. 2 hard track days at Beaver Run and 1 hard day at gingerman NO FADE AT ALL! I haven't even bleed the brakes, pedal is just as firm as when I started.
I'm sure any one that road with me can attest to the brake performance as they all commented on how late I was able to brake (SackDZ, Effect, Lance,..........)
Great upgrade for the price
P.S. This set-up will be for sale very soon.
Mattj
Old Apr 21, 2003 | 03:37 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: NSX caliper review (Dropspeed)
How soon and how much?!
Old Apr 21, 2003 | 03:40 PM
Flux's Avatar
Default Re: NSX caliper review (Rguy)
What is the weight of the NSX calipers (are they 4 piston?) compared to stock? And what is the size of the Legend rotors compared to stock? Thanks.
Old Apr 21, 2003 | 03:42 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: NSX caliper review (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">What is the weight of the NSX calipers (are they 4 piston?) compared to stock? And what is the size of the Legend rotors compared to stock? Thanks. </TD></TR></TABLE>
NSX calipers are two piston. Rotors go from 25mm to 28mm.
Modified by Rguy at 1:45 AM 4/22/2003
Old Apr 21, 2003 | 04:02 PM
743power's Avatar
Looks like you burnt your rotor. Did you have the brakes on after you stopped?
Old Apr 21, 2003 | 04:06 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: NSX caliper review (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">Looks like you burnt your rotor. Did you have the brakes on after you stopped?</TD></TR></TABLE>
WHAT?
Old Apr 21, 2003 | 04:08 PM
zer0zer0 TypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">
NSX calipers are two piston. Rotors go from 23mm to 28mm.</TD></TR></TABLE>
2 piston on each side so they are a 4pot system.
Old Apr 21, 2003 | 04:12 PM
Phoenix_ITR's Avatar
Default Re: NSX caliper review (zer0zer0 TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0zer0 TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
2 piston on each side so they are a 4pot system.</TD></TR></TABLE>
i could have sworn that each caliper only had two pistons...
-tony
Old Apr 21, 2003 | 04:15 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: NSX caliper review (delinquent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delinquent &raquo;</TD></TR><TR><TD CLASS="quote">
-tony</TD></TR></TABLE>
They do. He is wrong. If they were four piston there would be a bleeder valve visible and bumps for the pistons.
Old Apr 21, 2003 | 04:16 PM
P1mpSlap's Avatar
Damn!!!!! That is awesome!!!
You must tell us how this conversion is done.
You think I could do it on my GSR?
Old Apr 21, 2003 | 04:33 PM
DsITR's Avatar
Default Re: (P1mpSlap)
What made you choose the NSX caliper instead of the Legend caliper??
...other than the *bling* factor of course.
Old Apr 21, 2003 | 04:39 PM
sslude's Avatar
Default Re: (dsludefosho)
i know a guy that just got NSX calipers on his SI, freakin nice stopping power. looks good.
Old Apr 21, 2003 | 04:49 PM
Flux's Avatar
Default Re: (sslude)
Okay, I have to ask how much this conversion costs...
Old Apr 21, 2003 | 04:55 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: (Flux)
What setup are you using and do they clear 15" wheels?
Old Apr 21, 2003 | 05:02 PM
Dropspeed's Avatar
Default Re: (FrostyDC4)
It is the NSX calipers, Legend 28mm thick rotors, 2mm spacers and Hawk blue pads in the pictures.
No the rotor is not burned there, that must be brake dust, dirt?????
Yes they clear 15" wheels, Those are 15" Kosei K1s in the picture.
They are 2 piston calipers
I choose them because they became available from a friend.
Mattj
Old Apr 21, 2003 | 05:13 PM
RagingAngel's Avatar
Default Re: (Dropspeed)
Mattj
Do you still have the dust/heat shields behind the rotors? Any cooling ducts?
Old Apr 21, 2003 | 05:17 PM
Dropspeed's Avatar
Default Re: (RagingAngel)
No dust shields,
Cooling ducts:
Mattj
Old Apr 21, 2003 | 06:01 PM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">It is the NSX calipers, Legend 28mm thick rotors, 2mm spacers and Hawk blue pads in the pictures.
Mattj</TD></TR></TABLE>
There is a certain year and trim of Legend that comes w/2piston calipers as well...I believe its the GS?? I've never seen them, but have had many references say the pistons are actually bigger.
They are $85 @autozone... NSX run you around $300 correct?
Someone correct me if I'm wrong
Old Apr 21, 2003 | 06:43 PM
migs's Avatar
Joe, they are actually 2 piston. Its just 2 pistons on the inside and none on the outside.
Old Apr 21, 2003 | 06:49 PM
IGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">No dust shields,
Cooling ducts:
what kind of ducts are those?
Old Apr 21, 2003 | 07:06 PM
euclid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sslude &raquo;</TD></TR><TR><TD CLASS="quote">i know a guy that just got NSX calipers on his SI, freakin nice stopping power. looks good. </TD></TR></TABLE>
what type of rotors is he running? and did he need brackets for the calipers to bolt up to his hub?
Old Apr 21, 2003 | 07:40 PM
vactor's Avatar
Default Re: (euclid)
i put the legend dual pistons and legend rotos on my civic. love 'em
Old Apr 21, 2003 | 07:53 PM
TypeR 01 886's Avatar
nice... wish I had the money for the conversion... i need to get faster bef0re i have to stop faster
Old Apr 21, 2003 | 07:57 PM
Bbasso's Avatar
nice Review. And those Air ducts look rather sweet in person .
Old Apr 21, 2003 | 07:59 PM
migs's Avatar
Default Re: (Bbasso)
Matt,
How does your 32mm hub nut look rounded off?
