ITR Dash into EG
I just wanted to know if any of you guys up here has put an Integra dash into your EG.I have a 99 ITR dash with cluster and I wanted to know how hard is it to put this dash into my EG.How hard is the wiring?I've heard you have to cut the EG door panel and the Integra door panel in half and fiberglass the two together to get it to fit the dash is this true?Any info would be helpful.
You probably would have to cut & join doorcards if you want the dash to match the doors when you close them. I don't know for sure, but it makes sense as you might not be able to shut the doors properly if there are bumps on the EG doorcars that line up with the EG dash, but are mismatched with the ITR dash.
How about just fitting the ITR cluster in your EG dash? That's what I'd do.
This probably hasn't been much help..
wiring wasnt super hard once you figure out the trick to pop the pins out of the ecu plugs.
you also need both dash harnesses.
i did a 2000 gsr into my 92 dx and its all good.
you have to cut the plastic behind the cluster on the backside of the dash out or it wont go back far enough and that plastic sits on the steering column support.
i also had to cut some plastic off the backside of the far right a/c vent so the dash would go back far enough..
then you need to make dash brackets .
ill take a pic of mine later and show exactly how it fits and little things i found along the way.
and i "heard" teg door panels dont fit.
and the cutting both in 1/2 thing i think your thinking of putting a teg front end on a civic. you have to splice the fenders.
i am putting a dc2 mugen front end on my hatch and i had to splice a fiberglass oem dc2 fender to a metal civic fender.
Chris_Gee
12
Dec 18, 2021 07:57 PM
Chris_Gee
Dec 20, 2006 11:21 AM
