How can you tell if you have a blown headgasket or piston rings??
Old Apr 21, 2003 | 02:46 PM
TORQUE MONSTER's Avatar
Default How can you tell if you have a blown headgasket or piston rings??
I'm getting coolant in my oil.. but no oil in the coolant reservoir. I did a compression test and #1,#3,#4 are getting 98 and #2 is getting 180 like it supposed to.. I'm also blowing crazy gray smoke out the exhaust. My breather hose is shooting crazy coolant mixed with oil..
is it a blown head gasket or piston rings or both??
thanks for your help
Old Apr 21, 2003 | 02:55 PM
Default Re: How can you tell if you have a blown headgasket or piston rings?? (TORQUE MONSTER)
ok the color of the smoke is blueish gray
Old Apr 21, 2003 | 03:19 PM
DLB1994's Avatar
what kinda car is it
Old Apr 21, 2003 | 03:23 PM
integra95's Avatar
its the head gasket.
Old Apr 21, 2003 | 03:36 PM
Default Re: How can you tell if you have a blown headgasket or piston rings?? (DLB1994)
ohh sorry i didnt think it'd matter..
its a eg hatch with b20b jdm motor stock internals t3/t4 rev hard turbo kit
Old Apr 21, 2003 | 03:37 PM
Diego Boost's Avatar
Default Re: How can you tell if you have a blown headgasket or piston rings?? (integra95)
coolant in the Oil means either blown HG or cracked sleeve.
Old Apr 21, 2003 | 03:44 PM
Default Re: How can you tell if you have a blown headgasket or piston rings?? (Diego Boost)
how can i be absolutly sure cause i dont want to pull the head and find out its not the HG.
Old Apr 21, 2003 | 03:55 PM
genop's Avatar
is there oil on the plugs?
Old Apr 21, 2003 | 04:02 PM
Default Re: How can you tell if you have a blown headgasket or piston rings?? (genop)
nope nothng abnormal..it just burns rich but its not soaked in oil
Old Apr 21, 2003 | 04:08 PM
Mr. Softee's Avatar
blue is probably rings. headgasket is usually tons of white. headgasket there will be oil in the coolant and the car will overheat.
Old Apr 22, 2003 | 05:20 AM
Default Re: How can you tell if you have a blown headgasket or piston rings?? (94goldjungsr)
yeah it may actually be "white" smoke.. I know i'm getting lots of oil in my exhaust pipes though
Old Apr 22, 2003 | 05:25 AM
MiraiZ's Avatar
mine did that...had grayish blue smoke...turned out to be both
Old Apr 22, 2003 | 05:27 AM
Default Re: How can you tell if you have a blown headgasket or piston rings?? (MiraiZ)
sigh!!!
Old Apr 22, 2003 | 05:29 AM
is there a way i can be sure before i start tearing the **** apart?
Old Apr 23, 2003 | 07:53 PM
anyone
Old Apr 23, 2003 | 07:56 PM
MotorMatrix.com's Avatar
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TORQUE MONSTER &raquo;</TD></TR><TR><TD CLASS="quote">how can i be absolutly sure cause i dont want to pull the head and find out its not the HG.</TD></TR></TABLE>
doesnt matter either way. you gotta pull the head to change the rings or headgasket.
Old Apr 23, 2003 | 08:03 PM
sweet's Avatar
Default Re: How can you tell if you have a blown headgasket or piston rings?? (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">doesnt matter either way. you gotta pull the head to change the rings or headgasket. </TD></TR></TABLE>
exactly, so just pull the head and see if it's the HG. then go from there...
Old Apr 23, 2003 | 08:11 PM
dustin's Avatar
Default Re: How can you tell if you have a blown headgasket or piston rings?? (sweet)
Cracked ring lands.
Old Apr 23, 2003 | 08:28 PM
alright so be it
540guy
Apr 15, 2008 04:27 PM
garnet
Oct 6, 2007 02:02 PM
wullie_vtec
Apr 5, 2006 06:07 PM
VvPeachyvV
14
Dec 9, 2004 06:38 AM
SleepyHF
Apr 12, 2004 08:05 AM
