assessing parts condition...
Old Apr 21, 2003 | 02:46 PM
servion's Avatar
Default assessing parts condition...
Is there a way to determine the condition of my oil and water pumps? I've got them both off...I'm rebuilding the motor. I'd like to know if I should replace them or not.
Old Apr 21, 2003 | 03:14 PM
joe_bocc's Avatar
Default Re: assessing parts condition... (servion)
How many miles are on the engine. If its high mileage then change them while you have the engine apart.
Old Apr 21, 2003 | 04:14 PM
servion's Avatar
Default Re: assessing parts condition... (joe_bocc)
high mileage is in the eye of the beholder... I don't know the miles on my motor.... I'm guessing around 70k.
Old Apr 21, 2003 | 04:16 PM
psi420's Avatar
If you are unsure of the mileage, and or think the mileage is 70K, then I would advise replacing them.
Whats a couple hundred dollars extra for peace of mind of your motors vital components.
Old Apr 21, 2003 | 05:42 PM
servion's Avatar
Default Re: (psi420)
I suppose you're right... I was hoping to find a wey to determine now good/bad it is....
Old Apr 21, 2003 | 07:36 PM
joe_bocc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">If you are unsure of the mileage, and or think the mileage is 70K, then I would advise replacing them.
Whats a couple hundred dollars extra for peace of mind of your motors vital components.</TD></TR></TABLE>
I agree. You should also consider when the engine would be rebuilt next. If you don't replace them now and down the road they fail it would cost you more money.
Old Apr 22, 2003 | 07:16 AM
servion's Avatar
Default Re: (joe_bocc)
I am planning on changing them both...good advice. I still would like to know if there is anything specific I can check for to determine if they are worn (the next time I'm faced with a similar situation)
sullycrx
Jul 30, 2007 09:33 AM
FrostyDC4
Acura NSX
Sep 19, 2006 06:36 AM
IntegraGSR(-1)
May 1, 2006 09:22 PM
mawkiemarc
24
Mar 17, 2005 06:07 AM
redINTEGRAdriver
Feb 20, 2005 07:38 PM
