slight hesitation in second gear 95 H22
I have a 95 H22 VTEC
A lot of miles on the car, but the bottom end is rebuilt. I'ts pretty much stock except for KYB shock. I've gotten it service. cap/rotor/plugs, new clutchmaster/slave cylinder, new clutch/flywheel/throwout bearing/air filter/PVC/oil change/timing belt changed/new axles/CV-Boots. Plus I cleaned out the IAC screen last weekend.
I have two main issues.
1) there is a slight hesistation in 2nd gear, but in no other gear, around 2500-3000 rpm
2) My idle is still rough around 750 rpm.
Any help would be appreciated. Thx
this might help https://honda-tech.com/zerothread?id=471427
oh yeah we never finished talking about that... so does the prelude react well with aftermarket wires or are new stock wires better??
i still havent gotten time to get a new fuel filter either.....thats this weekends plans, so ill let you know if that helped any
coo, I was thinking it was maybe a fuel pump/fuel filter issue, but why only second gear?????
Also I still can't figure out this idle issue.
mine only does it......well i only notice ....it in first and second....and only Sometimes on the first run through the gears since its been started
I've done everything mentioned here
fuel filter
plug wires
plugs
o2 sensor
timing
cap
rotor
There might be more also, but thats all I can think of now.
fuel filter
plug wires
plugs
o2 sensor
timing
cap
rotor
slammedef06
Aug 16, 2006 02:52 PM
VSBB6
Apr 20, 2006 08:54 AM
