5$ Custom VTEC Engagement system
Hey there fellas. I've just installed a 5$ custom VTEC engagement system on my 2k Si. I can engage VTEC at any time I want. All I did was wire a 12 volt switch to the VTEC solenoid wire @ the ECU and installed a 12 volt doide between the switch and the ECU so as not to send 12 volts into my ECU and possibly damage it. I was just wodering what possible damage if any I may experience. I know that my oil pressure is too low below 4500rpm so that's as low as I'll try to engage VTEC. The only Problem I've run into is throwing codes if I forget to disengage the VTEC as I spin dow to idle. I would appreciate and feedback. Thanx Guys.
I can do it cheaper then $5 bux, but even free its a worthless mod.
if you really wanted to you can notch the o ring at the base of the spool valve and have it on all the time and not burn up the soleniod. but we have seen this on race only applications.
not only is this a stupd mod/post u must not know a damn thing about oil pressure at 4500 RPM. if u did know about oil pressure u would know that u have plenty of pressure for VTEC engagement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaatwsu »</TD></TR><TR><TD CLASS="quote">not only is this a stupd mod/post u must not know a damn thing about oil pressure at 4500 RPM. if u did know about oil pressure u would know that u have plenty of pressure for VTEC engagement. </TD></TR></TABLE>
Oil presure has nothing to do with why this is stupid!!!
It is stupid because if you set VTEC anywhere else then where it is without mods to justify the change, and a dyno to make sure your not loosing power, then you WILL loose power!!!
The VTEC lobes are designed to make power at a cerain point. You DO NOT gain power simply by lowering VTEC!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v00tecsi »</TD></TR><TR><TD CLASS="quote">
sure it does dumbass: and heres the quote "I know that my oil pressure is too low below 4500rpm so that's as low as I'll try to engage VTEC"
last time i checked SIs, GSRs, and ITRs all shared the same oil pump. GSR has vtec set at 4400 and besides that there is plenty of oil pressure below that too. thats my point. if u didnt understand my first sentence i said this was a stupid mod/post. i didnt think it was that hard to understand.
you dont have to rag on the guy, just school him/her. that mod will do nothing for you unless you have cams or some other kind of mod. your car is set to engage vtec at that point so that you get the best of the bottem end and the best of the high.
The stupidest part is that he is manually engaging VTEC, which means that he has to manually disengage it.
last time i checked SIs, GSRs, and ITRs all shared the same oil pump. GSR has vtec set at 4400 and besides that there is plenty of oil pressure below that too. thats my point. if u didnt understand my first sentence i said this was a stupid mod/post. i didnt think it was that hard to understand.</TD></TR></TABLE>
im pretty sure there is a difference from the gsr oilpump to the itr one.
Well for all you smartasses out there just answer this question! Why did this mod shave two tenths off my 1/4 times!?! If it's so dumb and pointless why does it make my car faster huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigphlip »</TD></TR><TR><TD CLASS="quote">Well for all you smartasses out there just answer this question! Why did this mod shave two tenths off my 1/4 times!?! If it's so dumb and pointless why does it make my car faster huh?</TD></TR></TABLE>
2 tenths huh? so what is that like a 17.89 1/4 time? y0!
show me a timeslip.. or maybe what was your 60'... 1/8mile/speed... 1/4mile speed.. I can pull numbers out of my *** to..and when you flipped the switch did it kick in and lose all traction since it seems to be like Nitrous to your car
