Where is the OEM Foglight fuse?
Old Apr 21, 2003 | 02:30 PM
superfuji57's Avatar
Default Where is the OEM Foglight fuse?
I have a 95 integra and I think i blew the fuse for my OEM foglights but i can't find the fuse. The switch near the e-brake handle isn't getting power.TIA
Old Apr 21, 2003 | 06:12 PM
integrx's Avatar
New User
Default Re: Where is the OEM Foglight fuse? (superfuji57)
sure its not the buld? the fuse is probably under the hood? i don't know but with aftermaket fog light its under the hood near the battery.
Old Apr 22, 2003 | 12:53 AM
Default Re: Where is the OEM Foglight fuse? (integrx)
positive its not the bulb
thanks i'll check under the hood
Old Apr 22, 2003 | 02:11 AM
akhom's Avatar
Fog lamp fuse if you have the OEM setup is at the under dash fuse block.
It should be a seperate unit attached to the top right side of the main fuse block.
It is a self enclosed unit.
Look for it.
Old Apr 22, 2003 | 02:33 AM
tC_Dragon's Avatar
Default Re: Where is the OEM Foglight fuse? (akhom)
yup, if they properly installed the oem foglights the factory way, then the fuse is in a seperate fuse holder directly aabove the regular fuse box located under ur steering wheel/cointray area. it may be labeled with a sticker
Old Apr 22, 2003 | 04:05 AM
The Poopsmith's Avatar
Default Re: Where is the OEM Foglight fuse? (pdcdragon)
I am about to get an OEM wiring harness to hook up the OEM fogs I have for my 96 teg. Could Somebody post a How To on the install for the fogs?
If not, then it looks like I'm gonna have to bust out the friends digi cam to write something
Old Apr 22, 2003 | 11:38 AM
tC_Dragon's Avatar
Default Re: Where is the OEM Foglight fuse? (DeeSeeToo)
where in the hell were you able to source an oem fog light wiring harness by itself????? i've been lookin for one of those forever!!! IM me.. .i'll send you by email the factory instructions for wiring install.
N1NjA TuRtLE
14
Aug 5, 2012 05:55 PM
frank358fr
Honda Civic (2006 - 2015)
10
May 9, 2009 10:51 PM
recaroem2
Honda Civic (2001 - 2005)
Nov 5, 2008 01:58 PM
truevietluv636
Mar 1, 2007 09:46 PM
ahloung
12
Mar 16, 2006 08:00 PM
