Dilemma
Old Jun 28, 2001 | 07:35 PM
DeL B18C SoL's Avatar
Default Dilemma
For the past few days I have been thinking about going all motor. All my friends are telling me not to and just put on my turbo( have not done it yet because I'm going to the Philippines&Guam) so I can be like them. I want to know is it possible to go all motor and have 210HP to 220HP daily driven on a B18C motor? If so can someone give me a good setup?
Old Jun 28, 2001 | 07:58 PM
raene's Avatar
Default Re: Dilemma (DeL B18C SoL)
They're called Toda Spec B cams... look into them . Also get titanium valvesprings & retainers, lightweight valves, and some higher-compression pistons. You should be easily running 220 whp with that setup.
But if you already have the turbo, why not bolt it on? Turbos are cheaper than N/A in the short run .
Old Jun 28, 2001 | 07:59 PM
blaze's Avatar
definetly possible with the right amount of money and patience... and all with oem parts. headwork, itr/ctr pistons, cams, itr manifold, jdm header, etc, etc.....
Old Jun 28, 2001 | 08:51 PM
I know about Toda, as well as JUN cams. There are some people in my neighborhood running Toda A and B Spec cams. Just wanted to hear from people with B18C all motor setups. I can't put the turbo on right know because I'm going to the Philippines&Guam in a couple of weeks so all my money is tied up with the trip and JDM parts I will be buying over there. Every Dyno Chart I have seen for daily driven B18C set up have all been in the 190HP to 205HP range. I have a spare B18C1 head in my garage and I was debaiting if I should sell it or send it to JG to have them work the head if I choose to go all motor.
NAbrothers
11
Feb 21, 2006 04:19 AM
HydroBudz
Oct 26, 2005 05:11 AM
Ruby Civic
Dec 27, 2003 10:14 AM
STEALTHMODECOUPE
Jun 14, 2002 06:45 PM
BuddhaSiR
Dec 4, 2001 11:19 PM
