just got $4k from the bank and want to go turbo
Old Apr 21, 2003 | 12:55 PM
ebp 99 si's Avatar
Default just got $4k from the bank and want to go turbo
i finally got my money (not as much as i wanted but atleast i got some)
what should i go with
i've found a few good deals
i found this and the guy said he wanted 4k but i offered him 3200
i have to watch my money
B SERIES TURBO KIT COMPLETE BRAND NEW
GARRET 60-1 "P" TRIM
SPEARCO FMIC
35MM WASTEGATE
TIAL BOV
VORTEC FMU
KOOKS CUSTOM MANIFOLD
JE 10.0 PISTONS
PAUTER RODS
then i found a sleeved gsr block for around 1000
what else would i need?
Old Apr 21, 2003 | 01:22 PM
mamaboy's Avatar
Default Re: just got $4k from the bank and want to go turbo (ebp 99 si)
https://honda-tech.com/zerouser?cmd=login
Old Apr 21, 2003 | 01:31 PM
ebp 99 si's Avatar
Default Re: just got $4k from the bank and want to go turbo (mamaboy)
well that deal went through
he said like a half hour ago he wanted 4k
i offered him 3600 and now he's sayin he already sold it
oh well
Old Apr 21, 2003 | 01:49 PM
mamaboy's Avatar
https://honda-tech.com/zerothread?id=482023
Sorry about that...I'm selling my almost complete "Kit" check it out
Old Apr 21, 2003 | 02:00 PM
ebp 99 si's Avatar
na that's ok
i found this complete kit for $3k shipped
Custom spec Turbonetics To4E/T3 60-1 turbocharger
DRAG 4 into 1 Cast Iron Turbo Exhaust Manifold
TIAL Wastegate Boost adjustable up to 20psi with boost controller.
Large Spearco front mount intercooler with polished cast aluminum end tanks (the largest intercooler you can fit on Honda without cutting)
Your choice of a Greddy Type-S, Blitz DD, or HKS SSQ blow off valve
DRAG Mandrel-Bent Chrome-Plated Piping 2 1/4 IN/ 2 1/2 OUT CHARGE PIPE
DRAG 2.5" Exhaust Down Pipe
DRAG Blue Silicone Couplers and Clamps
High flow secondary inline fuel pump -Vortech 12:1 calibrated boost dependent fuel pressure regulator
High flow DRAG intake system with funnel ram filter
Wastegate dump tube (forces the exhaust gases down and away from your air vents)
Map Sensor Bypass Valves
Heavy duty black vacuum line
Steel braided Goodrich dash-8 oil feed line
Heavy duty insulated oil return line
All necessary hoses, brass fittings, bolts, clamps and gaskets
NGK spark plug wires
Old Apr 21, 2003 | 02:33 PM
Smashback's Avatar
Sounds like a good one too. Drag manifold, FMU, and an -8 feed line. Damn, steer clear of that stuff dude.
Old Apr 21, 2003 | 02:38 PM
done's Avatar
stay away from fmus haha
Old Apr 21, 2003 | 02:42 PM
Vampyre's Avatar
Default Re: just got $4k from the bank and want to go turbo (Jordo)
call 512 834 8771
ask for tri or fadi. they have a pretty good deal on the drag gen 3 kit if thats what you want.
Old Apr 21, 2003 | 04:38 PM
ebp 99 si's Avatar
Default Re: just got $4k from the bank and want to go turbo (Vampyre)
i just talked to the guy and he said the turbo is a t4e 60-1
and i was goin with hondata anyways
**** fmu's
and i have a sleeved gsr block on the way for $1100 shipped
Old Apr 21, 2003 | 04:39 PM
ebp 99 si's Avatar
where can i get a good equal length manifold for a decent price
and also what size line should i use
Old Apr 21, 2003 | 04:43 PM
DaveF's Avatar
http://www.fullrace.com
thats all you need to know
rhdDC2b20
Northwest (Sales)
Nov 11, 2010 11:52 AM
The Dirty EJ1
Jun 19, 2007 06:57 AM
BEEYOND
Jan 31, 2007 11:19 AM
mugenhatch92
Apr 19, 2005 02:44 AM
BlownEJ6
Aug 24, 2003 06:49 PM
