can you do this?
Old Apr 21, 2003 | 12:22 PM
wm5holla's Avatar
Default can you do this?
can u put itr pistions in a ls block with out a vtec head?
Old Apr 21, 2003 | 12:32 PM
Katman's Avatar
Default Re: can you do this? (wm5holla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">can u put itr pistions in a ls block with out a vtec head?</TD></TR></TABLE>
yes you can, but I think there might be a slight clearance issue w/the valve relief area on the piston and the LS valves.... I'm not to sure/clear on this though, but B-series VTEC pistons will fit into an LS block no problem.
Old Apr 21, 2003 | 12:50 PM
The Crow's Avatar
Yes, you can and it will be fine.
Old Apr 21, 2003 | 01:11 PM
wm5holla's Avatar
Default Re: can you do this? (The End)
i heard u use stock ls pistion with a vtec head, it just wont fit? i wanted to go lsvtec.. then i was thinkin about some else.. i hate to be like other people for exmpale gsr in a hatch is sooo common. i was thinking aboyt all motor b18b.east like b18b motor with itr pistion and other lil goodies shunk2 mainfold , itr cams too... but **** work safely?
Modified by wm5holla at 3:25 PM 4/21/2003
Old Apr 21, 2003 | 01:12 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">i heard u use stock ls pistion with a vtec head, it just wont fit? i wanted to go lsvtec.. then i was thinkin about some else.. i hate to be like other people for exmpale gsr in a hatch is sooo common. i was thinking aboyt all motor b18b.east like b18b motor with itr pistion and other lil goodies shunk2 mainfold , itr cams too... but **** work safely?</TD></TR></TABLE>
dude... you cant use ITR cams on a non vtec head.
Old Apr 21, 2003 | 01:20 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">i heard u use stock ls pistion with a vtec head, it just wont fit?</TD></TR></TABLE>
That's a known issue.
You will run into valve-to-piston cleareance issues if you keep LS pistons and put a DOHC VTEC head on aka LS/VTEC. You're either suppose to (1) replace the LS pistons w/any DOHC VTEC pistons (depending on your motor application) or (2) have the LS pistons valve relief area porked (lol) out so the valves won't tap the pistons.
Old Apr 21, 2003 | 01:31 PM
wm5holla's Avatar
Default Re: can you do this? ()
Katman what is porked? i will i have valve-to-piston cleareance issues with a a ls block and head with itr pistions or any vtec pistions?
Kamin but icoud use toda or shunk too rite?
Old Apr 21, 2003 | 01:46 PM
Katman's Avatar
Default Re: can you do this? () (wm5holla)
ok..
im only typing this one more time...
with an LS/VTEC setup, you can use ANY B-series DOHC VTEC piston, meaning you will NOT have to modify the valve relief area. You only need to modify the valve relief area if you stick with an LS piston; you have to open up the valve relief area (aka pork) (ok ok ...bad slang).
bottomline...
If you go LS/VTEC go with a B-series DOHC VTEC piston; screw using the LS piston they suck anyways.
Old Apr 21, 2003 | 01:53 PM
dfoxengr's Avatar
yes, i think you have to open up the valve reliefs a little or get a slightly larger HG
Old Apr 21, 2003 | 02:23 PM
wm5holla's Avatar
Default Re: can you do this? (Katman)
i understand what u said but what i was askin.. itr pistion on LS rods with a LS head
Old Apr 21, 2003 | 02:38 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">i understand what u said but what i was askin.. itr pistion on LS rods with a LS head</TD></TR></TABLE>
It should work, but like I said, I'm not 100% sure about the valve relief/clearance issue when using an LS head & ITR pistons in a LS block.
But the ITR pistons will fit on LS rods, no doubt.
Old Apr 21, 2003 | 02:44 PM
wm5holla's Avatar
how do i find out about-&gt;&gt;valve relief/clearance issue
ITR pistons on LS rods, all day
Old Apr 21, 2003 | 02:57 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">how do i find out about-&gt;&gt;valve relief/clearance issue
you need to clay the clearances
http://www.c-speedracing.com has a how-to
honda_tuner10
Oct 19, 2006 07:30 AM
B18C5_EJ
Jun 4, 2006 11:15 AM
Wolfwood
Jul 12, 2005 10:20 AM
limegreenneon
Nov 21, 2003 04:03 AM
88whitehf
May 8, 2003 07:36 AM
