how much can a ls take with nitrous
Old Apr 21, 2003 | 08:44 AM
krazykid's Avatar
Default how much can a ls take with nitrous
if i have retared the timing 2 degrees have colder plugs from zex and a fuel pump. how many shots can i take safely with no problems at all like if the most i can do is lets say 80 im gonna do 65
Old Apr 21, 2003 | 09:07 AM
NY-Trizz's Avatar
I got a 97 GS with a stock fuel pump and regulator, with NGK stage 2 cold plug. I put about a hundred shot in, wich was way to much. I ended up melting the two middle spark plugs and tourching a couple of exhaust valves. Now the most i inject is about a 50 short, no problems at all.!!!!
Old Apr 21, 2003 | 09:26 AM
Novtec1's Avatar
Default Re: (NY-Trizz)
yea 65 is good that what i run in my 91 ls......
Old Apr 21, 2003 | 10:29 AM
Boost Ambassador's Avatar
Make sure you change the spark plugs and you'll be fine w/ a nice 50 wet or dry shot! Happy hunting
Old Apr 21, 2003 | 10:39 AM
GSRwBOOST's Avatar
Default Re: how much can a ls take with nitrous (B20Demon)
i ws squeezing a pro-shot with a two stage 200 shot w/ 4 sequential bottles on a stock LS block.... worked great....
Old Apr 21, 2003 | 11:17 AM
CNSK's Avatar
Default Re: how much can a ls take with nitrous (GSRwBOOST)
take your hp to the wheel and divide that by 2. I think thats the best way to shoot.
Old Apr 21, 2003 | 11:49 AM
arsenaldragster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRwBOOST &raquo;</TD></TR><TR><TD CLASS="quote">i ws squeezing a pro-shot with a two stage 200 shot w/ 4 sequential bottles on a stock LS block.... worked great....
seriously?? WTF were you running?? 200shot on stock block.. not likely.
I shot 75 on stock internals. (NX) The only problem i had was traction!
Old Apr 21, 2003 | 03:35 PM
krazykid's Avatar
i called nos and they told me dont go more than a 60 shot so u will have enough fuel for sure. they go just get spark plugs and u dont need a fuel pump running 60 just get a gauge and a bottle warmer later if u want. i guess im gonna do that and get a fuel pump anyway to be really safe
Old Apr 21, 2003 | 03:56 PM
DK4200's Avatar
i am running a 65 shot with stage 2 NGK plugs and i have had no problems... i raised my fuel pressure to about 48 psi. Im gonna try the 75 shot at the track one day and hopefully everything will be cool. i got the ZEX kit. it is great
Old Apr 21, 2003 | 05:17 PM
ThisLittleSleepeR's Avatar
i got a complete NOS kit for sale, brackets, lines, full bottle, micro switch, fuel and nos solenoids, and original NOS blanket. $350 picked up.
3 plus 1
Mar 10, 2004 10:50 PM
BlackB18CTeg
Sep 23, 2003 05:52 PM
tmekjian
May 1, 2003 09:53 AM
integra1884
Jan 6, 2003 07:26 PM
