3 quick fuel questions.
Old Apr 21, 2003 | 06:00 AM
baonest1's Avatar
Default 3 quick fuel questions.
1. if fuel pressure is at 60psi using 270cc injectors and 190 fuel pump, should i upgrade to some 310cc so i can lower the psi?
2. is there any method I can use to see if injectors are flowing good instead of sending it off to RC engin.
3. if running 60psi with 270cc and 190 fuel pump, will that shut the car down or perhaps mess somthing up
thanx
Old Apr 21, 2003 | 06:39 AM
pills_PMD's Avatar
i would get larger injectors and lower the fuel pressure...
what engien management are you using??
Old Apr 21, 2003 | 09:05 AM
baonest1's Avatar
Default Re: (pills_PMD)
hondata
endlessdv
Jan 9, 2006 12:47 PM
ATS*Mark
Aug 7, 2004 10:12 AM
Red D Dragon
34
Apr 5, 2004 04:51 PM
spcmotorsports
Oct 9, 2002 05:24 AM
Tripz
May 6, 2002 06:04 PM
