Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why?
Old Apr 21, 2003 | 05:42 AM
Fuster_Cluck's Avatar
Default Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why?
I have no idea what is going on with my Hybrid. The other day the diagnostic threw code 22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch and I just checked it again this morning and now it's code 21 (VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve)
I'm going to check the wiring back to the shock tower and ECU and also the connection at the vtec solenoid...
Just have no idea why it would go from one code to the other. I did remove the vtec oil pressure harness the other day and plugged it back in. Maybe it was not on correctly and that is the problem with the solenoid valve
Be back in a minute......
Back ---> Checked the connections and everything looks good. Maybe time to take the car in to a shop :-(
93 Civic Cx
98 GSR motor (usdm)
Modified by Hybrid93Hatch at 11:03 AM 4/21/2003
Old Apr 21, 2003 | 07:23 AM
743power's Avatar
Default Re: Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why? (Hybrid93Hatch)
get a multi meter and make sure that you are gettintg voltage at your connections for those two switches. Also, the plugs for the vtec solenoid and oil pressure switch are pretty finicky from my experience, I unplugged mine once to replace a cam plug, and when I took my car out, there was no vtec. It turns out that the plug was not on all the way. Don't take your car to a shop after all the hard work you have done yourself.
Old Apr 21, 2003 | 07:26 AM
Default Re: Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why? (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">get a multi meter and make sure that you are gettintg voltage at your connections for those two switches. Also, the plugs for the vtec solenoid and oil pressure switch are pretty finicky from my experience, I unplugged mine once to replace a cam plug, and when I took my car out, there was no vtec. It turns out that the plug was not on all the way. Don't take your car to a shop after all the hard work you have done yourself.</TD></TR></TABLE>
Here's what I posted the other day in another post
"I'm also throwing Code 22.
Checked the vtec pressure switch and it's good.
I then checked the voltage for the blue/black wire and grounded the other pointer of the multimeter and only getting 1.03volts. The Helms says it should be close to 12v. I immediately checked the voltage at the battery and getting 12+.
It says to "Inspect for an open or short to ground in the wire between the VTEC pressure switch and the ECM (ECU) C15. If the wire is ok, substitute a known-good ECM and recheck"
Any ideas? Could it possibly be a bad ECU (OBD1 P72 is what I am using)?
I can try my friends ECU (same Hybrid).
Thanks!"
This was when I was throwing code 22 only. Now it's just 21. I was a quart low on oil so I am thinking that could of been the cause of 22. I'll check the voltage again on the harnesses.
Thanks!
Old Apr 21, 2003 | 07:40 AM
b18c-93's Avatar
New User
hey man don't fell bad i did a swap yesturday in a 93 integra with a gsr everything works well except i am getting a code 21, so i tried a friend of mine ecu and same ****, so i tried another friends ecu that was upgraded an has no 21.so whats up with that
Old Apr 22, 2003 | 04:37 AM
Default Re: Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why? (b18c-93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c-93 &raquo;</TD></TR><TR><TD CLASS="quote">hey man don't fell bad i did a swap yesturday in a 93 integra with a gsr everything works well except i am getting a code 21, so i tried a friend of mine ecu and same ****, so i tried another friends ecu that was upgraded an has no 21.so whats up with that </TD></TR></TABLE>
Interesting! I'm going to try my firends ECU next time I see him.
Old May 15, 2003 | 09:45 AM
granada_sun's Avatar
werd, my friends got a b16 swap that throws 22 on chipped usdm p28, but when i put jdm p30 in no codes.....i read somewhere on this site that jdms dont have vtec pressure switch??
Old May 15, 2003 | 10:05 AM
slowdx's Avatar
Default Re: Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why? (Dark_Sol)
i have a 95 dx with a 95 gsr motor and once in a while the 22 would come on then when i woke up the next morning 21 came on, i chenaged the oil and made sur ei wasnt low and problem solved.
Wierd huh?
saintbhts
Jun 12, 2013 09:43 PM
wrxya33
Jul 6, 2007 08:16 AM
Sleepy_Red_hatch
11
Oct 16, 2006 07:42 AM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
typer_801
Mar 19, 2002 07:08 AM
