hoses sizes
Does anyone know the size for the following hose ( the inner diameter if possible)
water pipe to the IAC controller
pvc vavle to intake manifold
charcoal canister to the vavle thing on top of the manifold
this is off a 96 integra ls
does anyone know where the charcoal canister hose go to, beside the one that goes to the fuel tank
thanks
thanks
Probably 1/4" ID for the larger hoses (eg: PCV valve) and 3/16" or 1/8" for the smaller ones.
For the EVAP system, the big hose on the top of the charcoal can goes into the throttle body nipple. One of the small ones goes aft to the tank for the 2-way valve, the other small one goes to the EVAP solenoid by the ****.
The other end of the EVAP solenoid valve gets run to a nipple on the IM for engine vacuum.
This is for a OBD-I B18B1, but I don't think they changed much except for the placement of the EVAP purge solenoid valve.
Enta
Jan 29, 2007 03:51 AM
vietnamese0utlawz
May 19, 2006 09:46 PM
JerseySiPOS
12
May 16, 2004 10:40 AM
citanest
Jan 14, 2002 10:26 PM
