Fuel line/hose question
well i just put my intank fuel pump in and i took out the inline one .. There is a problem though. You know how when you put an inline one in, you have to cut your fuel hose to get teh inline one in there and the connect those? well right now i have two hoses that arent connected and you cant get those hoses off cause apparantly they are crimped on? can you take those off? what is a way around it? my thought was to just get a thinner hose to go inside the stock hose that doesnt reach and connect it from one end to the other and use clamps to tighten and secure it???? or will this not work? any help is appreciated, thank you
Well one of the Earls' braided stainless fits over the honse almost perfectly... you could get some of the hose, and get some econo fit hose ends and clamp it down real good.
man did i get lucky, i called my import shop and drove an hour to get a brand new stock fuel line that goes from the fuel filter to the rail, with fittings attacthed and everything. 10 bucks
carlos8
Dec 17, 2013 12:30 AM
