WTF!!! Oil in the turbo houseings..
This turbo install will never end I tell you!!! Ok I have the Fuel worked out .. But now I have Oil going in to the houseings WTF!!! The Turbo is brand ******* new IS there a brake in I need to? THe cat is now cloged with oil and the car is missing bad the ecu keeps trying to up the fule and I keep trying to take it out.. HELP Did I miss something and I think the bearings are starting to sqweak.... AHHHHHHH...
Re: WTF!!! Oil in the turbo houseings.. (IntegraXSi)
What are you using for the oil supply line? (specifically the size of the line)
Where are you getting the supply feed from? (where on the block)
I'm gonna bet you have excessive flow and oil pressure in the center housing. This is the cause of the oil leaking past the shaft seals and into the turbine/compressor housings.
