Need help.....Im confused!!!
Old Apr 20, 2003 | 08:34 PM
jdm_integ's Avatar
Default Need help.....Im confused!!!
I have a ls/vtec in my 91 integra. And i have a p28 ecu on the way to run it hopefully. well since i have to use a jumper from obd0 to obd1, i heard that there are alot of things i have to change and here they are:
****Depending on the type of engine transplant you are performing (B or D-series), you must get these respective B or D-series parts in order to complete the OBD1 conversion which in turn, will satisfy the OBD1 ecu's programming.
- Obviously you need an OBD1 ecu..
- An OBD1 distributor
(B or D-series depending on the type of engine transplant you're doing, if any)
- OBD1 distributor male plugs
(they're all the same style for civics and integras)
- A 92+ civic/integra 4-wire 02 sensor.
- A 92+ civic or 94+ integra Vehicle Speed Sensor aka VSS.
- Lastly, an OBD1 thermostat housing w/integrated thermo-switch sensor.
... these parts are all needed in order to complete the OBD1 conversion along with rewiring and implemenation of OBD1 distributor plug(s).****
I GOT THIS FROM JDMHONDAPARTS.COM CAN SOMEONE TELL ME IF ALL THIS IS CORRECT.
Old Apr 20, 2003 | 08:40 PM
jdm_integ's Avatar
Default Re: Need help.....Im confused!!! (jdm_integ)
BUMP
Old Apr 21, 2003 | 03:37 AM
jdm_integ's Avatar
bump please
Old Apr 21, 2003 | 02:11 PM
Jeff C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_integ &raquo;</TD></TR><TR><TD CLASS="quote">- A 92+ civic or 94+ integra Vehicle Speed Sensor aka VSS.
I did not do these two and mine is alright.
Old Apr 21, 2003 | 02:12 PM
Katman's Avatar
Default Re: Need help.....Im confused!!! (Jeff C)
yep..those 2 items are optional.
Old Apr 21, 2003 | 03:37 PM
torr's Avatar
Default Re: Need help.....Im confused!!! (Katman)
how do you convert my stock 1 wire o2 sensor to a 4 wire o2 sensor? i know it's probably a tough question to ask with seeing it but, please try to explain this to me. thanks
Old Apr 22, 2003 | 05:36 AM
JimBlake's Avatar
Default Re: Need help.....Im confused!!! (torr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr &raquo;</TD></TR><TR><TD CLASS="quote">how do you convert my stock 1 wire o2 sensor to a 4 wire o2 sensor? i know it's probably a tough question to ask with seeing it but, please try to explain this to me. thanks</TD></TR></TABLE>
I don't think you can... The 4-wire sensors have a built-in heating element which gets the sensor hot & working faster when you start up. You need to get a heated O2 sensor.
Old Apr 22, 2003 | 06:19 AM
Jeff C's Avatar
You cant convert an obd0 ecu to use a 4-wire O2. You will need to get an obd1 ecu first.
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
darrenVT
18
Sep 30, 2008 09:18 AM
MniMeHatch89
May 24, 2007 09:10 PM
91dxcrx
Jan 22, 2006 05:46 PM
hi-Powered
Apr 30, 2005 01:28 PM
