question regardin timing...
Old Apr 20, 2003 | 08:19 PM
speedaccordinly24's Avatar
Default question regardin timing...
hi everyone,
have a ? regarding timing, how do you know if your timing is off? and how do i go about checking this? my 97accord 2.2 is backfiring and its nothing ignition wise, ive changed and checked everything (plugs,cap,rotor,coil,dist, etc) jus wana know what are sum of the symptoms of bad timing and how i can go bout fixing this.
thanks,
m
Old Apr 21, 2003 | 08:10 AM
JimBlake's Avatar
Default Re: question regardin timing... (speedaccordinly24)
You can check your valve timing by taking off the timing belt cover & checking the alignment marks on your cam sprocket. A repair manual will have specifics, look up the section on replacing your timing belt.
Check your spark timing with a timing light. The light should have instructions.
miguey310
Aug 21, 2010 09:20 AM
technine
Apr 2, 2009 10:36 AM
slow-ef
Mar 26, 2009 10:53 AM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
speedaccordinly24
Apr 20, 2003 08:56 PM
