Mugen chipped pr3 questions...
i have a 88 CRX with a B16. does a Mugen chip totally eliminate o2 sensors? because im thinking about getting a race header in the future. thanks in advance.
PR3.MDS
PROGRAM TYPE::::
DOHC VTEC program with disabled sensors (Mugen variant)
VTEC RPM POINT::::
[choose one] 4800 | 5200 | 5500 | 5700
REDLINE RPM POINT::::
[choose one] 8800 | 9000 | 9200 | 9500 | 10k
FUEL & TIMING::::
maps are enhanced moderately
SENSOR INFO::::
Disabled VTEC pressure switch
Disabled knock sensor
Disabled 2nd 02 sensor
Disabled speed limiter
DYNO TESTED?::::
[ not yet ]
NOTES::::
Most widely sold program I have for the PR3 ecu. Not only is this a great race program for the 88-91 civc/crx and 90-91 integra, it makes wiring up VTEC less of a hassle since all you have to wire up is the VTEC solenoid sensor!
Having tested the listed sensors disabled, it does not hurt anything performance-wise on a naturally aspirated engine. Gas mileage will slightly drop with this program.
ISSUES::::
A few people have reported that they have issues with a low idle/cold start, but once the engine warms up it runs fine. Also, when the A/C kicks on the idle drops low and sometimes the engine will stall.
Taken from JDMHondaparts.com.
PROGRAM TYPE::::
VTEC RPM POINT::::
FUEL & TIMING::::
SENSOR INFO::::
DYNO TESTED?::::
[ not yet ]
NOTES::::
ISSUES::::
actually, if the chipping is authentic mugen, both O2 sensors are bypassed....unless the programs that are copied are different..i'm running a real mugen pr3 in my car, and is disables both o2....just to let ya'll know
Smog check? Whats that?
We arn't subjected to the sniffer test outside the city where I live. The mugen program is great. I run a VAFC to help cut back some of that extra fuel. The Mugen chip is also good for the LS/VTEC.
i think http://www.locashracing.com let me check on that we rewired mine for 2 o2 sensors...there is no knock sensor, that's it
i ordered my chip from Kenji. got it in a couple days.. haven't installed it yet though.. probably next week when i put in my ITR cams, intake manifold, jg throttlebody
i got the mugen chip with all sensors enabled, 5.5k vtec and 9K revlimit
oops.. did i say that out loud?
Modified by madeiniraq at 11:01 PM 4/23/2003
http://www.hyperducktuning.com/ has a diy kit where they send you the chip with two programs, you choose the programs, they have the mugen chip $35.
i recently socketed my authentic pr3 mugen egu, and i have the bin file saved if you have a eprom programmer. This one does not require any O2 sensors guaranteed. PM me if you want the program.
