Project Si decided to take a dump out of nowhere :(
well today i decided to clean my garage since i just finished the car...
pulled it out of the garage, clean my garage...about 20 minutes later go to pull the car back in and tha bitch wont start!!!!!!
tried swapping distributors from another Si...doesnt work
did a compression check...178 across....
check timing...good
fuel pump....good
changed plugs...nothing
changes missing link/map sensor.....nothing...
i'm stumpped....have no clue what the hell it might be...it just wont crank over....
if anyone has any clue what it may be, please let me know!!!!! TIA
check timing...good
fuel pump....good
yes it has spark...like i said i just came back from the dyno yest....the car started fine today and 20 mintues later wont start anymore
you check your fuses?? I had a similar situation....after three days of slaving over my car I found that the asg fuse found its way out
so it cranks but won't turn over right? check the ground wire by the thermostat. happened a lot on EF's w/ swaps. see it's screwd in properly.
Jeff-
Jeff-
amej8
Jan 31, 2016 06:55 PM
Audio28
Jul 3, 2003 05:33 PM
