Project Si decided to take a dump out of nowhere :(
Old Apr 20, 2003 | 06:41 PM
VisualAutoMotoring's Avatar
Default Project Si decided to take a dump out of nowhere :(
well today i decided to clean my garage since i just finished the car...
pulled it out of the garage, clean my garage...about 20 minutes later go to pull the car back in and tha bitch wont start!!!!!!
tried swapping distributors from another Si...doesnt work
did a compression check...178 across....
check timing...good
fuel pump....good
changed plugs...nothing
changes missing link/map sensor.....nothing...
i'm stumpped....have no clue what the hell it might be...it just wont crank over....
if anyone has any clue what it may be, please let me know!!!!! TIA
Old Apr 20, 2003 | 06:48 PM
turbod16y8's Avatar
Default Re: Project Si decided to take a dump out of nowhere :( (ProjectEF)
what kind of fuel management? try resetting the ecu.
Old Apr 20, 2003 | 06:50 PM
eh2666's Avatar
It doesn't crank or it doesn't start? Do you have spark?
Old Apr 20, 2003 | 06:57 PM
Default Re: Project Si decided to take a dump out of nowhere :( (eh2666)
yes it has spark...like i said i just came back from the dyno yest....the car started fine today and 20 mintues later wont start anymore
Old Apr 20, 2003 | 07:03 PM
Tomek's Avatar
you check your fuses?? I had a similar situation....after three days of slaving over my car I found that the asg fuse found its way out
Old Apr 20, 2003 | 07:04 PM
Default Re: Project Si decided to take a dump out of nowhere :( (AztecEJ)
check all fuses under the hood, inside the car....with test light....all good....
Old Apr 20, 2003 | 07:06 PM
Disco Stu's Avatar
Can you compression start it?
Old Apr 20, 2003 | 07:12 PM
Default Re: Project Si decided to take a dump out of nowhere :( (Disco Stu)
didnt try that
Old Apr 20, 2003 | 10:05 PM
SpeedMonkeyRacing's Avatar
so it cranks but won't turn over right? check the ground wire by the thermostat. happened a lot on EF's w/ swaps. see it's screwd in properly.
Jeff-
amej8
Jan 31, 2016 06:55 PM
HEADS OR TAILS
Jun 13, 2010 07:08 PM
boosted_lude
Jun 14, 2007 01:32 PM
JDMlyfestyle
22
Jan 9, 2004 10:36 AM
Audio28
Jul 3, 2003 05:33 PM
