Timing belt and Crank bolt
Old Apr 20, 2003 | 06:34 PM
cjDC2's Avatar
Default Timing belt and Crank bolt
I am all out of ideas about this so I hope you can help. I am doing the TB on my 96 GSR. And as you know you have to remove the crank bolt to access the lower TB cover. I cannot get it off!!! I know there is a special wrench, but I have a lightened underdrive pulley so the tool doesn't work. If anyone has done this and has a method that works it would be gretly appreciated asI have tried everything,including the impact gun, and one really long breaker bar!
Old Apr 20, 2003 | 06:37 PM
MachAF's Avatar
Default Re: Timing belt and Crank bolt (cjDC2)
How many ft/lbs is the impact wrench you used? An air or electric one?
A 240ft/lb electric one should do the trick - you can rent it from a local store I'm sure.
Old Apr 20, 2003 | 09:10 PM
Rayman's Avatar
Default Re: Timing belt and Crank bolt (MachAF)
Try the air gun. If that doesn't work, try a chain wrench to hold the pulley. It's a plumbing tool. Last resort would be to pull the tranny and clutch. Then use the flywheel bolts to hold the crank pulley steady. Good luck.
Old Apr 20, 2003 | 10:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Timing belt and Crank bolt (Rayman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rayman &raquo;</TD></TR><TR><TD CLASS="quote">Try the air gun. If that doesn't work, try a chain wrench to hold the pulley. It's a plumbing tool. Last resort would be to pull the tranny and clutch. Then use the flywheel bolts to hold the crank pulley steady. Good luck.</TD></TR></TABLE>
pull the lower flywheel cover off, and the teeth are right there. No need to pull the tranny.
Old Apr 21, 2003 | 05:04 AM
Stewie's Avatar
Default Re: Timing belt and Crank bolt (PatrickGSR94)
I use a chain wrench to take my stock pulley off. It would work for you too.
Old Apr 21, 2003 | 06:35 AM
JeremyL's Avatar
Default Re: Timing belt and Crank bolt (Mac8008)
have some stand on the brake pedal while you crank the hell out of the bolt
Old Apr 21, 2003 | 03:21 PM
Rayman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
pull the lower flywheel cover off, and the teeth are right there. No need to pull the tranny. </TD></TR></TABLE>
Good point. That would work. Don't like the idea of trying to hold it by the the flywheel's teeth though.
Old Apr 21, 2003 | 03:28 PM
tilt's Avatar
I jam a hex bit, like the screwdriver bits for a drill, in the flywheel teeth. Place it just before the bump in the tranny casing and that keeps it from moving. Then use a breaker bar and have at it.
Daniel Deyette
Jun 14, 2016 09:47 PM
douglaslovin
Sep 15, 2005 06:42 AM
93gsrcoupe
Sep 30, 2004 09:54 PM
crxcess
Feb 19, 2004 08:24 PM
NAZC
11
Jan 15, 2003 04:52 AM
