SRS light came on after install of tv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02AccordCoupe »</TD></TR><TR><TD CLASS="quote">Hi, I just installed an lcd screen and dvd player and now i have an srs light, do you guys know what could be the cause of this?</TD></TR></TABLE>
same thing happened when i had my indash installed...only way to reset it is take it to the dealer...they'll charge an arm and a leg to reset it but what can you do...theres also a thread here with a DIY SRS reset...you can try that if you want to..
its not that expensive...its about 40.00 - 50.00 i think...
I've gone to the dealer since and they reset it for free, but do you think it will come back? By the way they said the computer showed something to do with electronics.
what type car? I might be able to tell you how to reset it. I know exactly where on the Civic's (well like 96 up for sure) and the prelude is near that location. It's a plug up to the left of the steering column that you jumper to reset the SRS system... but honestly unless you have a helms infront of you and you're going over everything STEP BY STEP I wouldn't do it.
you can also disconnect you battery for a period of time (usually at least 10 minutes or more) and it will reset the dummy lights. If it is indeed something you did wrong, the light will probably come back on though.
Always know one thing about dealers.....if you have any sort of aftermarket electronice in your car (radios, alarms, etc...) they like to blame problems on the electronics. I see it every day in my shop, and 9 times out of 10 they are wrong.
Its gone, and still hasnt come back so i'm not sure if it was the tv at all. They probably just saw the wires hanging out (since i took my tv and dvd out so they wouldnt scratch it).
ROB8387
Dec 16, 2006 02:00 PM
undercoversi
10
Oct 4, 2004 11:18 AM
