radio will not turn on
Old Jun 28, 2001 | 10:34 AM
freud's Avatar
Default radio will not turn on
my parents have a 91 Accord EX and recently took it to a repair shop to have the car worked on. as standard practice they take out the radios in the cars they are working on and lock them up in a cabinet to prevent theft.
however, when they replaced the radio they were unable to turn the radio on. i took a look at it myslef and checked the wiring and everything is wired correctly, i know the radio is receiving power because the lights around the bass/treble control ***** and other various lights turn on but the radio itself does not turn on; this is on both an aftermarket unit and stock unit. i've even taken the radio out and installed it in my CRX and it works fine. what gives?
any help would be appreciated.
Old Jun 28, 2001 | 10:37 AM
SOHCArchangel's Avatar
Default Re: radio will not turn on (freud)
check the fuse for the radio, it could be blown,....
Old Jun 28, 2001 | 11:56 AM
Bootie Monger's Avatar
New User
do you need to put in a security code? on my stock radio i had to push a sequence of buttons before it would work after the battery was pulled.
Old Jun 28, 2001 | 12:08 PM
Default Re: radio will not turn on (Bootie Monger)
code is only needed for the stock radio,...
Old Jun 28, 2001 | 10:38 PM
mld's Avatar
mld
New User
Default Re: radio will not turn on (SOHCkordVTEC)
you should try going to your local car audio shop i'm sure they can help you out.. i was thinkin the security code but since its still messed up w/ your new unit as well i don't know what the problem is..
Old Jun 28, 2001 | 11:56 PM
New User
maybe a bad ground somewhere? a bad ground could make the internal amp clip. look at the wiring twice, in my car i tried to add a fan to the remote for the amp i have and it sent it in to safe mode (shutdown), wouldn't work unless i had the wiring perfect.
Old Jun 29, 2001 | 09:09 AM
freud's Avatar
thanks for the help guys. i'll see what i can do this weekend with it and hopefully will have some good news to report.
maylcy
Acura TL, RL & ZDX
Jan 31, 2011 06:03 AM
KiD Fr0m Da 516
Jul 24, 2005 02:44 PM
KiD Fr0m Da 516
Audio / Security / Video
Jul 24, 2005 01:55 PM
iHATEspeedbumps.
Jul 24, 2005 07:03 AM
durand202
Acura TL, RL & ZDX
Jul 10, 2005 09:11 PM
