Resetting ECU on GSR
Old Apr 20, 2003 | 01:24 PM
pRosmAt3c's Avatar
Default Resetting ECU on GSR
How do i reset the ECU on a '99 GSR? There is no mention of "ECU" on the fusebox, so I have no clue what to do. Thanks.
Old Apr 20, 2003 | 01:26 PM
neo1z's Avatar
Default Re: Resetting ECU on GSR (pRosmAt3c)
Unhook the negative battery cable. Sit for a minute. Put it back on. Let the car idle for 5 minutes. Turn off the car. Turn it on. Cruise away.
Old Apr 20, 2003 | 01:50 PM
MooreBoost's Avatar
Default Re: Resetting ECU on GSR (neo1z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">Unhook the negative battery cable. Sit for a minute. Put it back on. Let the car idle for 5 minutes. Turn off the car. Turn it on. Cruise away.</TD></TR></TABLE>
Is all this really neccesary? I thought all you had to do was unhook the battery for like 10 mins?
gmoore
Old Apr 20, 2003 | 02:03 PM
VTECorona's Avatar
Default Re: Resetting ECU on GSR (tegunderpressure)
Disconnect battery for 5-10 minutes, reconnect it and let it idle for 5 minutes so that the ECU can adjust itself. Make sure you have your stereo security code before disconnecting ur battery
Old Apr 20, 2003 | 02:21 PM
MooreBoost's Avatar
Default Re: Resetting ECU on GSR (97RedTegGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote"> let it idle for 5 minutes so that the ECU can adjust itself. </TD></TR></TABLE>
Ahhh, makes sense. Good stuff.
gmoore
piggydog
Jun 27, 2006 11:07 AM
Boring
10
Dec 3, 2004 11:31 AM
ieatrice
10
Jul 24, 2004 08:34 PM
chronodyne28
Jul 7, 2004 10:31 PM
FroggyR
Mar 10, 2002 05:36 PM
