What do i do with a stripped head bolt??
is there ANY way I can get the head bolt off when it's partially stripped? i don't want to strip it anymore... stupid craftsman socket cracked so it stripped it partially... please help.. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GottaLude »</TD></TR><TR><TD CLASS="quote">vice grips</TD></TR></TABLE>
I dont think you can use vise gripd on the headbolts, they are recessed in the head.
were you able to loosen it at all before stripping it?
yeah i was using a 6pt 14mm and it snapped which kinda stripped the bolt... and now i'm afraid it'll be stripped completely if i try again.
i was only to loosen the bolt a 1/4 a turn
the dremel the bolt idea is great! i think i'll try that.
anymore inputs before i do?
thanks!
thanks!
i think craftsman has a stripped bolt remover i did that to on e fo the headbolts i stripped it came right out with no problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak »</TD></TR><TR><TD CLASS="quote">nah it's a 6pt 14mm bolt.. i tried the 13mm 6pt.. too small</TD></TR></TABLE>
go to sears and ask them for the stip bolt remover i beelive it comes in a set of 10mm to like 17 mm its about 20 bucks use it and return thats waht i did
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giovannie »</TD></TR><TR><TD CLASS="quote">
go to sears and ask them for the stip bolt remover i beelive it comes in a set of 10mm to like 17 mm its about 20 bucks use it and return thats waht i did</TD></TR></TABLE>
Slick *** move
I'll remember to do that in the future
Slick *** move
Get the metriwrench set! Dont knock it till you tried it cause it saved my *** a few times when the craftsman sockets didnt want to grab.
those stripper removers works great.. i have set here as well they are 17.50 at local sears.
next time use a impact socket to take head bolts out. Those sockets dont give for anything and your not gonna snap em either...if you do your more of a man than i am
tensaiwung
27
Mar 28, 2012 10:02 AM
