Poping out of 4th gear while driving 40 mph!!??
Old Apr 20, 2003 | 10:44 AM
el arbi's Avatar
Default Poping out of 4th gear while driving 40 mph!!??
Today I was driving my car around, wasnt pushing it at all, next thing i know once i shift from 3rd to 4th, i touch the gas and it pops out of gear. I did it 3 times, happened all three times to. Then i juss skipped 4th all the way home scared shitless. What the hell happenn???
Old Apr 20, 2003 | 01:34 PM
ThrillaKilla's Avatar
Default Re: Poping out of 4th gear while driving 40 mph!!?? (99SiRacer)
depending on your gear ratios 40 mph is really slow for 4th gear, at least in my s1.. id only be at like 1500- rpms which is near the idle RPM level, if its too near the idle speed it can be very easily taken out of gear or even forced out in that occasion... im just guessing, its probably something else
Old Apr 20, 2003 | 02:41 PM
Patch's Avatar
Default Re: Poping out of 4th gear while driving 40 mph!!?? (ThrillaKilla)
Sounds like your tranny is fucked up to me (I've been working in a transmission repair shop for about 6 months). Check out some of your local transmission shops, most of them will diagnose your car for free. Let a couple of them drive it for different opinions, but it may be a bad syncro. Actually, before you go ahead and get it checked out, change your tranny fluid. Use Honda MTF.
Old Apr 20, 2003 | 07:46 PM
el arbi's Avatar
Default Re: Poping out of 4th gear while driving 40 mph!!?? (CRX PAT)
anyone else have any ideas??
Old Apr 20, 2003 | 08:11 PM
TREVER's Avatar
sounds like your trannies fucked up good diagnosis. The gears are held in by detents that can become jammed. there are 2 14mm bolts that hold in a spring and ball remove these to see if the ball is crushed into the bolt.
Old Apr 21, 2003 | 12:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThrillaKilla &raquo;</TD></TR><TR><TD CLASS="quote">depending on your gear ratios 40 mph is really slow for 4th gear, at least in my s1.. id only be at like 1500- rpms which is near the idle RPM level, if its too near the idle speed it can be very easily taken out of gear or even forced out in that occasion... im just guessing, its probably something else </TD></TR></TABLE>
I have never had the tranny pop out of gear unless there was a problem with the synchro. Sometimes I drive 40mph in 5th (still above 2000rpm in my GS-R). I have also had the engine pretty much idling while in 1st gear, just kinda pulling the car along (traffic jam). No problems w/ coming out of gear on mine.
Old Apr 21, 2003 | 03:48 AM
Patch's Avatar
Default Re: Poping out of 4th gear while driving 40 mph!!?? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
I have never had the tranny pop out of gear unless there was a problem with the synchro.</TD></TR></TABLE>
Hrm, he agress with me. Maybe it wasn't such a bad diagnosis dickface.
Old Apr 21, 2003 | 10:33 AM
92GSR2o3's Avatar
Try adding some more tranny fluid or change the fluid entirely, cause this happened to my friend once he has a 94 civic with a GSR motor swap and we'd be cruising on the highway in 5th gear and it would always pop out when the shifter is left alone so he would have to hold it in gear to drive. Hope that helps. Peace
Old Apr 21, 2003 | 11:00 AM
b16adx's Avatar
Default Re: Poping out of 4th gear while driving 40 mph!!?? (92GSR2o3)
A friend of mine had a GSR and his throw out bearing went bad and that caused his car to just pop out of gear during normal driving. Cheap part but u have to do basically a clutch installation to fix it.
Old Apr 21, 2003 | 05:29 PM
TREVER's Avatar
Hey internet gangster you wouldn't have the ***** to call me dickface to my face so don't do it here.
Old Apr 21, 2003 | 09:31 PM
PnX-R's Avatar
Sounds like there could be a problem with the Shift Rail.. I think Trever's right..
bigmaccrew
May 16, 2014 12:05 PM
snzh22
Dec 9, 2006 08:20 PM
torr
May 22, 2005 03:49 PM
gsring
Jun 10, 2004 10:26 AM
fangtl
Oct 4, 2003 06:19 PM
