Questions about Building an All Motor ITR.
Old Jun 28, 2001 | 09:10 AM
i 4's Avatar
i 4
Default Questions about Building an All Motor ITR.
I recently bought a 97 ITR and i right now i have $4000 dollars to put into the motor, i want to run mid to high 13's with the money i have right now (allmotor). i was also wondering what i would need to do to be in the 12's?
This is what i had in mind for right now:
Ignition
CTR intake Cam
Skunk 2 gears
Fuel pressure regulator
Skunk ECU
Tanabe Racing Medallion ( any susgestions on exhaust? )
JDM 4-1 , or DC SPORT JDM 4-1 headers
Mugen Head Gasket
and Nitto street slicks
( thats like a $3000 price tag )
Old Jun 28, 2001 | 09:20 AM
Big Phat R's Avatar
Default Re: Questions about Building an All Motor ITR. (AllMoToR97ITR)
Strip the **** out of it to get the weight down to about 2200 lbs and you'll be there.
[Modified by Big Phat R, 10:20 AM 6/28/2001]
Old Jun 28, 2001 | 09:26 AM
i 4's Avatar
i 4
Default Re: Questions about Building an All Motor ITR. (Big Phat R)
hehe..i want to keep this car with a full interior...
Old Jun 28, 2001 | 09:32 AM
Big Phat R's Avatar
good luck then
Old Jun 28, 2001 | 10:12 AM
Dropspeed's Avatar
[This is what i had in mind for right now:
Ignition
CTR intake Cam
Skunk 2 gears
Skunk ECU
Mugen Head Gasket
( thats like a $3000 price tag ) [/QUOTE]
I would save the money on the CTR cam, With a cam Gear on the dyno there is very little difference. Also I would only start with one cam gear on the intake, from MY experiance on the dyno with the stock cams in 2 different motors there is little gain to be had on the exhaust side. Why bother with labor involved in installing the headgasket unless you plan on getting some headwork/valvetrain upgrade at the sametime. If your going to run a header and exhaust 86 the factory cat and install a high flow or a test pipe. Those are just some qwik thoughts
Mattj
[Modified by Dropspeed, 11:13 AM 6/28/2001]
Old Jun 28, 2001 | 12:43 PM
FAST94GSR's Avatar
New User
Default Re: Questions about Building an All Motor ITR. (Dropspeed)
Get headwork, and bump up your compression, get a real header like hitech, cam gears, vafc, and tune the hell out of it. aem intake , custom exhaust.
Old Jun 28, 2001 | 12:52 PM
i 4's Avatar
i 4
Default Re: Questions about Building an All Motor ITR. (FAST94GSR)
where do i get SMS headers or Hitech??
Old Jun 28, 2001 | 01:03 PM
HapaHaole's Avatar
you want both adjustable cam gears if you start milling hte head or go with a thinner head gasket. i would go with higher compression pistons.
Old Jun 28, 2001 | 01:05 PM
Big Phat R's Avatar
Try this:
https://honda-tech.com/zerosearch?di...&query=headers
Old Jun 28, 2001 | 01:06 PM
i 4's Avatar
i 4
Default Re: Questions about Building an All Motor ITR. (yeah LS)
yeah i am also planing on Spoon balanced JDM ITR pistons along with the head gasket.
Old Jun 28, 2001 | 01:16 PM
kenji's Avatar
25 Year Member
AllMoToR97ITR,
If you want to get your ITR in the mid 13's for right around $4000 or less (definitely less) I can do it for you. I am located about 30 minutes north of Tampa. Email me at kenji211@gte.net
I have went 13.7 @ 102 on street tires in my '98 ITR with less than $3000 in mods. I still have the stock head and the stock block.
-kenji
Old Jun 28, 2001 | 01:39 PM
i 4's Avatar
i 4
Default Re: Questions about Building an All Motor ITR. (kenji)
ok what are your mods...i'll drive to tampa , what are you planing on doing to it . you can email me at vincelanz@hotmail.com
Old Jun 28, 2001 | 02:39 PM
kenji's Avatar
25 Year Member
Here was my setup when I ran the 13.7 @ 102:
Iceman intake (get the AEM, it works better but fits like sh*t)
64mm TB
cam gears
Mugen headgasket
JDM ITR header
test pipe
5Zigen Border304 exhaust
Skunk2 ECU w/one of my OBD2 to OBD1 ECU conversion harnesses
Toyo T1-S 205/50-15 @ 25 psi.
-kenji
[Modified by kenji, 3:42 PM 6/28/2001]
Old Jun 28, 2001 | 02:40 PM
Zeus's Avatar
Endyn B20z short block...
Old Jun 28, 2001 | 03:07 PM
Mike M's Avatar
Founding Member
Default Re: Questions about Building an All Motor ITR. (Zeus)
CTR Pistons
Headwork, not just a P&P
Spoon Header
Slicks
Contact me if you want some suggestions
Old Jun 28, 2001 | 07:09 PM
AJ PwR's Avatar
1st Suggestion: (Engine Power)
Spoon Header, CTR Pistons and reprogramming your ECU.
2nd suggestion : (Power delivery)
ATS Close gear ratio set, Spoon Race LSD , ACT or Spoon Race clutch and any light weight Flywheel.
If you can built you motor to have big power but you can't have the power deliver to the wheels so what's the point?
[Modified by AJ PwR, 8:09 PM 6/28/2001]
Petah
Jan 25, 2009 03:03 AM
boostedeghatch
22
Oct 20, 2004 03:38 PM
InfamousRS
Apr 24, 2002 08:22 PM
FUP23
Jan 6, 2002 04:03 PM
jdmteg
Jul 12, 2001 01:25 PM
