Just got b20 swapped in, now throws code 45 (too rich or too lean)
Old Apr 19, 2003 | 08:34 PM
MikeMAN's Avatar
Default Just got b20 swapped in, now throws code 45 (too rich or too lean)
code description:
45
System Too Lean or Too Rich malfunction in the fuel monitoring systems
I drove the car for over 300 miles home and then going down the last street to my house CEL comes on. I reset it for the heck of it to see if it came back, and sure enough...60 miles later or so it did.
I recently had a b20b block bolted up to my b16a2 head for a CRVTEC setup done by a shop. They said the engine is running a little lean up top (nothing bad, except performance hit) and to replace the b20 injectors with my stock b16 injectors when i get home. Aren't they the same size?
Any info on what it could be or what i should do would be appreciated!
Thanks,
mike
Old Apr 20, 2003 | 09:06 AM
MikeMAN's Avatar
Default Re: Just got b20 swapped in, now throws code 45 (MikeMAN)
anyone?
mike
Old Apr 20, 2003 | 10:02 PM
MikeMAN's Avatar
bump!
mike
Old Apr 20, 2003 | 10:42 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">Aren't they the same size?
Yes, 240cc I believe. I just finished my B20vtec swap last week. It's not throwing any codes, but I had fuel delivery problems the first day. I don't think it was running lean, but I didn't have a FPR. Without the FPR, the motor could barely start let alone run. What compression are you running btw?
Old Apr 21, 2003 | 08:44 AM
MikeMAN's Avatar
Default Re: (GapxGuy)
like low 9's, (b16a2 head with b20b block) all stock. I was thinking gettin a FPR because im thinking that even tho the displacement is only 2.0L, honda never made a 2.0L VTEC engine, so its not ready for the extra fuel required for VTEC.
thanks for the reply!
mike
oderfla90
Jun 22, 2016 07:03 AM
MX500
Oct 26, 2008 01:51 PM
boosted k20
Sep 11, 2004 07:32 PM
T3-T4TEG
Apr 19, 2004 01:16 PM
MikeMAN
May 2, 2003 01:54 PM
