How much boost/whp would you feel comfortable w/ on a stock b18c?
Old Apr 19, 2003 | 07:41 PM
BoostedGSRBubble's Avatar
Default How much boost/whp would you feel comfortable w/ on a stock b18c?
Im ordering my bigger injectors on monday so i can up the boost. Im @ 90% w/ my 440's @ 240whp and 6.5lbs. The motor has stock 10.6 comp and is very healthy. Im running s100 for fuel mgt and payn tunes pretty conservativley. I plan on a new block come wintertime, but not earlier. I figure 11lbs and ill be around 300whp. How much further would you push it, or would you?
Old Apr 19, 2003 | 07:44 PM
jinxproof99's Avatar
New User
Default Re: How much boost/whp would you feel comfortable w/ on a stock b18c? (BoostedGSRBubble)
up to 400 to the wheels with around 9.3:1 compression(3mm headgasket) and race gas. amount of boost is irrelevant.
Old Apr 19, 2003 | 08:40 PM
MiraiZ's Avatar
Default Re: How much boost/whp would you feel comfortable w/ on a stock b18c? (jinxproof99)
I would limit it to 10psi on stock pistons
Old Apr 19, 2003 | 09:36 PM
TeStUdO's Avatar
Default Re: How much boost/whp would you feel comfortable w/ on a stock b18c? (MiraiZ)
this topic is so dead. it all depends on your tuning when it comes down to it. you have hondata, as long as you get it tuned you could push 300 easy. good luck
Old Apr 19, 2003 | 11:31 PM
Default Re: How much boost/whp would you feel comfortable w/ on a stock b18c? (00si5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00si5 &raquo;</TD></TR><TR><TD CLASS="quote">this topic is so dead. it all depends on your tuning when it comes down to it. you have hondata, as long as you get it tuned you could push 300 easy. good luck </TD></TR></TABLE>
Yea, i searched thru the hundreds of threads and found that the ringlands become pretty volunerable around 300whp. The reason i asked was few were specific to my motor/comp. There were a few knowledgable folks who seemed confident that 320-330 with proper tuning, intercooler and other high quality components.
Old Apr 20, 2003 | 12:32 AM
-=-'s Avatar
My friend is boosting 10psi(daily) on his type r with just a headgasket =x he rest of the internals are stock.
Masho
Honda Civic (2001 - 2005)
Dec 9, 2010 11:34 AM
jeffchaisi
Mar 22, 2005 10:37 AM
k-cerez
15
Nov 25, 2004 08:59 PM
Ls-Rturbo
Apr 20, 2004 05:43 PM
Wrath of VTEC
Sep 15, 2003 06:58 PM
